02 fuel feed pipe leaking bad - Page 7 - Yamaha R6 Forum: YZF-R6 Forums
post #61 of 68 (permalink) Old 07-08-2014, 09:19 PM Thread Starter
Re: 02 fuel feed pipe leaking bad
so now the water jacket t is leaking.Guess I pushed to hard getting the clamp on.I guess Ill just plug the lines, ivans says on his carb kit to do so.
yzfr6chris is offline
post #62 of 68 (permalink) Old 07-08-2014, 09:32 PM Thread Starter
Is that gonna cause a problem
post #63 of 68 (permalink) Old 07-09-2014, 06:07 AM
UR B-hind Da 8 Ball
8Ball's Avatar
Bike: '03 R6, XR400, 79 GS550
Cold starts may be a bit tougher because that regulates the choke circuit, but I've seen quite a few that have been by-passed without an issue.
8Ball is offline
post #64 of 68 (permalink) Old 07-09-2014, 12:28 PM Thread Starter
ok cool, someone somewhere else said you had to re-jet but Im finding most are saying like you 8ball
post #65 of 68 (permalink) Old 10-02-2018, 03:45 PM
Sorry for bringing up this old topic.
I have the same leakage and the o-ring is 7.5x1.5mm.
Google for "Mikuni Carburetor O-Ring" or something like that... but you will find the size for small money.
Anyways I measured the T joint. 7.5mm inner dia and housing is around 9.45mm - so 7.5 with 1.5 thickness will fit, maybe a 7x2mm will also fit and be leakfree but no need cause 7.5x1.5 is available.
Hope it helps... I know that other bikes has same carb fuel pipes in use but didn't found a solid part number.
Acki84 is offline
post #66 of 68 (permalink) Old 09-09-2019, 08:09 AM
nova r6
tdoss1980's Avatar
Bike: 05 r6 Camo/Orange
Bumping and old thread, did those orings hold up? if so where did you get them, trying to help a buddy with his and its leaking from the same place
March 2014 Bike of the month
tdoss1980 is offline
post #67 of 68 (permalink) Old 09-09-2019, 08:47 AM
That are all O rings you need, replaced them last year. Some dimensions are no original but best fit.
File Type: jpg 202D745C-B19B-46C0-8390-1B931D8C3CF3_1568044023817.jpg (50.8 KB, 5 views)
Acki84 is offline
post #68 of 68 (permalink) Old 09-12-2019, 07:01 AM
nova r6
tdoss1980's Avatar
Thanks got it sorted!!
Fuel Leaking ChinoR1 Garage / Mechanical Help 8 10-08-2016 04:02 PM
Fuel leaking? ussoldier1984 Garage / Mechanical Help 4 10-04-2011 05:35 PM
Help with fuel leaking!!! Tony.666 Garage / Mechanical Help 3 01-15-2008 05:50 AM
03 R6 fuel leaking from the midpipe r6Lotus Garage / Mechanical Help 1 07-25-2007 10:51 PM
Leaking Fuel..HELP prkid424 Garage / Mechanical Help 2 07-25-2006 04:29 AM
