'17 Quick Shifter programming - Page 4 - Yamaha R6 Forum: YZF-R6 Forums
 15Likes
post #31 of 64 (permalink) Old 07-16-2017, 10:51 AM
Dakara's Avatar
Bike: 2017 R6
I installed mine the other day with no problems. Hold shifter up, turn ignition on, waited 10-12 seconds and the QS icon came on. My gear indicator showed I was in second gear when I turned the ignition on. Maybe try being in 1st gear, then holding shifter up and turning the ignition on.
Dakara is offline
post #32 of 64 (permalink) Old 07-16-2017, 04:56 PM
Maui's First 2017 YZF-R6
Mr. Pueo's Avatar
Bike: 2017 Yamaha YZF-R6
Re: '17 Quick Shifter programming
Yes, I went from Neutral to 2nd and kept holding.
2017 Yamaha YZF-R6 Team Yamaha Blue
GYTR Quick Shifter Kit • OEM R6 Seat Cowl • OEM R6 Tank Pad • OEM R6 Radiator Guard • OEM R6 Engine Cover Protection Set • OEM R6 Rear Stand Hook • OEM R1M Rear Seat Cowl • OEM R1M Front Carbon Fiber Fender • OEM R6 2018 Matte Grey Tail and Undercowl • Puig Double Bubble Smoked Windscreen • ASV Inventions Levers • Techspec Snake Skin Tank Pads • SC Project S1 Exhaust • MJS Headers • Graves Motorsports Block Off Plates • EDR Performance ECU Flash • EXUP Servo Deleted • Sprint Air Filter • Graves Motorsports Frame Slider • Lightech Front/Rear Axles Slider • Driven Racing Blue Endurance Axle Cups • Yamaha Brake Lever Guard by Gilles Tooling • Gilles Tooling Sprocket Guard • JL Designs Fender Eliminator Plug • TST Industries Under tail Relocation Kit • JL Designs Smoke Integrated LED Tail Light • Intelligent Lighting Systems, LLC DRL Mod • Matte Carbon Fiber Rear Hugger • Carbon Sprocket Cover • More Mods Coming Soon
Mr. Pueo is offline
post #33 of 64 (permalink) Old 07-17-2017, 06:49 PM
Originally Posted by Racer172 View Post
yeah I like to do everything I'm able to do on my bikes as well, I did the QS install myself and just a note: it can not be done in 15 min. I know that wasn't your main point just just wanted everyone to know you should plan on about an hour for the install or an hr of labor to have it done for you. 15 min to swap the shift rods and set the lever, etc.. but you also have to completely remove the gas tank from the bike and put it on your work bench (no way around this) removing the fuel line, 2 breather hose hoses, mail electrical plug and I think 1 other if I remember right, and you need a 2nd person to hold the gas tank up while you do these disconnects. Reason you have to remove the gas tank completely is the QS connection you have to get to is tucked away underneath other wires & hoses just on top of the engine. It is hard to find even with the gas tank off the bike. So if you are not comfortable doing this install yourself $80 is a reasonable price to have it done right for you.
I just installed this myself, I ended up unbolting the tank and shifting it to the side slightly. I was able to reach my hand in and connect the quick shifter to the harness. No need to take the tank completely off. I was able to program it pretty quick just by holding the gear shifter up and turning the ignition on, QS light came on after about 8 seconds.
Dayna21 likes this.
drmmstr06 is offline
post #34 of 64 (permalink) Old 07-18-2017, 08:28 AM Thread Starter
Track Time
Racer172's Avatar
Bike: R6, FZ-07, H2, zx-10r
I can see that working if you already knew exactly where your hands had to go to find the connection plug, but if you are searching blind for the first time it would be extremely hard without removing the tank completely, but whatever works for each person doing the install. You are EXTREMELY lucky to get the programming to engage in 8 sec.
my bikes: 2017 R6 on order... 2016 Ninja H2... 2013 Nina zx-10r racebike.. 2016 FZ-07
Racer172 is offline
post #35 of 64 (permalink) Old 07-18-2017, 09:13 AM
I had absolutely no idea where the connector was, you can create enough space to get your hand in there with a light and find it. Look at the connector from the quick shifter assembly and you can imagine what the other side of the plug will look like. As far as programming, it couldn't have been easier, I simply just followed the directions that came with it. You do have to have the kill switch on in order for the programming to work. I wonder if people are forgetting that.
Dayna21 likes this.
post #36 of 64 (permalink) Old 07-19-2017, 10:13 AM Thread Starter
Track Time
Racer172's Avatar
So the kill switch in the position so the bike can't/won't start, then turn the key on? I think this is the first time I'm hearing of this. Was that in the instructions?
Racer172 is offline
post #37 of 64 (permalink) Old 07-19-2017, 01:10 PM
Kill switch in the position so that the bike will start (sorry I worded that weird on my last reply). The first time I tried to program it I was unaware that I had the kill switch in the on position (so that the bike will not start) and it did not program. I then proceeded to turn the kill switch off (so that the bike will start) and it programmed after about 8ish seconds. This was not in the instructions.
Dayna21 likes this.
post #38 of 64 (permalink) Old 07-29-2017, 02:15 PM
I having the same. Won't turn on...
Sent from my SM-G935V using Tapatalk
rodriry is offline
post #39 of 64 (permalink) Old 07-29-2017, 02:50 PM
So kill switch on, in neutral, hold all the way up to 2nd, then turn the key on, wait 10 sec?
rodriry is offline
post #40 of 64 (permalink) Old 07-29-2017, 04:38 PM
yes exactly
Quick (down)Shifter cj360v8 General Discussions 12 10-29-2015 09:54 AM
pull type quick shifter and quick shifter module MELK-MAN Bike Parts For Sale 2 04-28-2015 07:46 PM
Quick Shifter sublime4mylife Bikes + Parts + Gear Wanted 6 07-28-2014 08:58 PM
Quick shifter street use TOPFLiTE1994 General Discussions 19 09-08-2013 08:51 AM
Using a quick Shifter racerboy434 Garage / Mechanical Help 1 04-22-2007 03:56 PM
