05 yamaha r6 (thoughts on dyno numbers??) - Page 2 - Yamaha R6 Forum: YZF-R6 Forums
 1Likes
post #11 of 18 (permalink) Old 09-08-2018, 07:51 PM
Why yes I don't!!!!!!!!!!
TurboBlew's Avatar
Bike: 2007 In Heaven
Re: 05 yamaha r6 (thoughts on dyno numbers??)
who cares about HP? Torque is whats more important... which youre not making more than 41 ft lbs...lol
TurboBlew is offline
post #12 of 18 (permalink) Old 09-09-2018, 08:39 PM Thread Starter
05-TYBE-R6's Avatar
Bike: 2005 YAMAHA R6
Garage
i guess i should have just asked you for all the info and spec of my bike
Current Rides:
*05 R6
*17 santa fe sport Awd
*05 Civic Lx
05-TYBE-R6 is offline
post #13 of 18 (permalink) Old 09-10-2018, 06:36 AM
FWIW, my "spare" bike ('05 R6) has a YEC ECU and a PC on it, Graves throttle body slide stops, Akrapovic full Ti exhaust, and was tuned by Livengood a few years ago. 113.31hp and 47.85 tq on pump gas. Case has never been cracked open, so stock pistons, rods, cams, etc. Brian obviously messed a lot with timing as well as the fuel map. It's a PITA to tune, since that version of YEC ECU required the timing changes to be made via the cluster. The numbers on the Dyno are pretty relative. What meant more to me is that he got it from 106.57hp/44.76 - and that 106.57 was with a PC map on it already. As usual, Livengood backs up his reputation.
That being said, I'm about to tear the bottom end off to service the transmission.....
'15 R1
'05 R6 (Old Faithful)
wmhjr is offline
post #14 of 18 (permalink) Old 09-10-2018, 05:14 PM Thread Starter
05-TYBE-R6's Avatar
Garage
I've been contemplating finding a 2nd motor to build, but id want to do the big bore kit (636) but the cylinders are nikasil and not steel sleeves? so machine shop would be $$$$
Current Rides:
*05 R6
*05 Civic Lx
post #15 of 18 (permalink) Old 09-11-2018, 07:04 AM
nova r6
tdoss1980's Avatar
Bike: 05 r6 Camo/Orange
Yea I have the 1mm over wiesco kit that again I got for a steal! like 200 bucks but yes entire top case has to be sent out bored and nikasiled
March 2014 Bike of the month
tdoss1980 is offline
post #16 of 18 (permalink) Old 09-11-2018, 08:59 AM
Hey...watch this
FZ1guy's Avatar
Bike: FZ1; R6; GL1800; SV650
Huey got 112 out of my 2005, and I believe the numbers on his dyno.
Mine is setup almost identical to yours.
FZ1guy is offline
post #17 of 18 (permalink) Old 09-11-2018, 04:29 PM Thread Starter
05-TYBE-R6's Avatar
Garage
thats not bad at all
i mean almost every dyno is going to read a bit different anyways
Current Rides:
*05 R6
*05 Civic Lx
post #18 of 18 (permalink) Old 09-12-2018, 07:02 AM
Nobody should ever "believe" the peak numbers on a dyno. Even if you try to adjust for barometric pressure, etc, every dyno is going to be different - and will typically even yield slightly different readings on the same exact bike on different days. The numbers on the dyno are best used to evaluate the curve, and to compare deltas between runs. So for me, I'm looking to see what the torque curve looks like to smooth out acceleration, and what the delta is between base run and tuned. Anything beyond that is just idle conjecture. That's why people bragging about their dyno sheets make me laugh. That only tells me that they don't understand what's going on.
05-TYBE-R6 likes this.
'15 R1
wmhjr is offline
R6 with R1 motor??? spiderbyte Garage / Mechanical Help 25 06-28-2006 10:23 AM
standard restrictions on the 03+ R6 NickRs125 Exhaust and fuel delivery 0 07-09-2004 11:49 AM
R6 questions! smoke General Discussions 18 05-05-2004 04:58 PM
DAZZLER 03 R6 DYNO RESULTS dazzler General Discussions 10 03-15-2004 03:43 PM
Performance Numbers for R6 Dman General Discussions 14 01-23-2004 04:25 PM
