2003 Yamaha R6 synthetic oil or no? - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 7 (permalink) Old 03-24-2019, 04:30 PM Thread Starter
JGreene_93's Avatar
I have a 2003 Yamaha R6 and this is my first bike. I’m wanting to go ahead and change the oil because I’m not sure when the last owner did but didn’t know if it mattered if I used synthetic oil or if I just needed to use regular oil.
JGreene_93 is offline
post #2 of 7 (permalink) Old 03-24-2019, 05:06 PM
Forum Moderator
Skeeter's Avatar
Bike: '03 Sliver R1'06 Raven R6
Images: 3
Re: 2003 Yamaha R6 synthetic oil or no?
It's fine to use. I'd go with 10w40. It's what I always put in my 2006.
Skeeter is offline
post #3 of 7 (permalink) Old 03-24-2019, 05:12 PM Thread Starter
JGreene_93's Avatar
Any recommended brand to use?
post #4 of 7 (permalink) Old 03-24-2019, 05:50 PM
I've always used Mobil1 4T 10-40w, but that is up to you. Depending on your climate, you might want different viscosity oil.
NotNattyR6 is offline
post #5 of 7 (permalink) Old 03-25-2019, 02:18 AM
Bike: 2015 R1
Garage
mobil 1 isn't actually synthetic unfortunately. that's why it's only $10 and $5 over priced. it's only petroleum that has undergone extra refining. yeah it's technically better than regular oil but it's still not a real synthetic oil and definitely lacks all of the benefits of true synthetics. a true synthetic oil is group 4 and group 5 oils. typically the bottle is typically labeled as 100% synthetic if it's real synthetic. real synthetic oil is polyol ester and polyalphaolefin.
anyway, if you want brands what are true synthetic, Yamalube, Motul, Maxima racing, MPT, redline, Bel-Ray, silkolene, amsoil. and many others. just look on the label. if you see ester on it, it's a good, real synthetic oil.
I'm currently running MPT this summer. tests results are not in but it sounds good on paper. although it seems they didn't fill the bottles completely and I need a 5th bottle to fill a 4qt crankcase.
yamahacrazy is offline
post #6 of 7 (permalink) Old 03-25-2019, 04:40 AM
Wow I guess I havent really looks closely enough into oil. That’s good to know, will definitely try one of those brands next oil change. Thanks for the info.
post #7 of 7 (permalink) Old 03-25-2019, 02:04 PM
Why yes I don't!!!!!!!!!!
TurboBlew's Avatar
Bike: 2007 In Heaven
I wouldnt put too much stock in "ester" vs mineral for normal operating conditions.
You can change mineral oil pretty frequently vs the ester ones and not sacrifice wear or service life especially on a factory built engine.
Also I will state that the so called synthetic Rotella in the blue bottle... is good enough to finish inside the top 10 at the Daytona 200.
Now if you embark on a superbike type engine build...then yes the esters are dramatically better but require frequent service intervals.
TurboBlew is offline
2002 fuel tank does it fit on 2003 r6??? Help Wallbug General Discussions 6 12-31-2018 09:05 AM
2003 r6 clocks r6dene Appearance and Exterior Mods 5 01-16-2004 11:26 AM
FYI: 2002 TiForce System fits 2003 R6 R6Elmo Exhaust and fuel delivery 6 10-24-2003 02:53 PM
