Please help, coolant keeps coming out of overfill hose. - Yamaha R6 Forum: YZF-R6 Forums
 3Likes
  • 1 Post By yamahacrazy
  • 2 Post By Betan
post #1 of 9 (permalink) Old 04-14-2019, 09:56 AM Thread Starter
Betan's Avatar
Hi can someone please point me to the direction to find information concerning this. I saw a post on it and I have been trying to find it but no luck.
I have a 05 R6 with 20k miles. The bike runs great does not over heat but it keeps spitting out coolant when it gets around 200-214°F at this time the fans would come on and I can hear the fluid boiling inside the radiator. I used up 1 gallon in 1 week refilling the reserve before every ride. I then decided to keep it a lil below half but still no difference. I then began riding my bike with only the radiator filled and would check and fill it before I take her out and monitor the temp during rides. I have had no problems but I know it's not safe for the bike so I am back filling up the reserve and it burns me seeing all that coolant keep spilling out. I use Prestone the green stuff. Can someone please help.
Betan is offline
post #2 of 9 (permalink) Old 04-14-2019, 10:12 AM
Bike: 2015 R1
Garage
Re: Please help, coolant keeps coming out of overfill hose.
I would replace the radiator cap. it sounds like it's not able to hold the pressure in the radiator anymore.
Straight Success likes this.
yamahacrazy is offline
post #3 of 9 (permalink) Old 04-14-2019, 12:26 PM Thread Starter
Betan's Avatar
Thanks a lot for the fast reply. I will definitely try that. I'm hoping its something I can easily replace. Will update as soon as I get it replaced to let you know how it went.
Betan is offline
post #4 of 9 (permalink) Old 04-14-2019, 12:30 PM Thread Starter
Betan's Avatar
I have 1 question, Would it leak out by the radiator cap if the cap is not holding enough pressure or only through the reserve?
Betan is offline
post #5 of 9 (permalink) Old 04-14-2019, 12:42 PM
UR B-hind Da 8 Ball
8Ball's Avatar
Bike: '03 R6, XR400, 79 GS550
That's the purpose for the overflow reservoir. When the pressure exceeds what the cap can handle, it leaks into the reservoir.
Also, you need to be sure the radiator is full. Don't just add coolant to the reservoir.If there is an air gap in the radiator, it won't suck fluid back into the radiator from the reservoir like it is supposed to.
Hopefully a new cap and a full radiator will solve your issue. If not, then your issue may be a leaking head gasket, and cylinder pressure could be blowing into the cooling system and just pushing the coolant out.
8Ball is offline
post #6 of 9 (permalink) Old 04-14-2019, 08:10 PM Thread Starter
Betan's Avatar
Thanks for your help. I always fill both the reserve and the radiator which us usually full. If it's a head gasket leak wouldn't it continuously blow in the radiator as the bike is started? I had started the bike a few times and had it run with the radiator cap off and didn't see any bubbles blowing while I reved it or kept the engine at idle. Or maybe it could be a really small leak I'm not sure but will definitely have it looked at. Thanks again.
Betan is offline
post #7 of 9 (permalink) Old 04-15-2019, 09:22 AM
Motosylum Racing #132
The Evil Twin's Avatar
Bike: R6, ZX6, R1200, 400 XC-W
+1 on a new radiator cap. FWIW, my reservoir is usually only filled to the LOW mark. It is normal for coolant to get pushed into it as temps go up and the coolant expands. But it should not overflow the reservoir.
Also, if there is an air gap in the radiator, it will get pushed out after a couple rides. The expansion will push the air out first since it is at the highest point.
2017 #1 Middleweight F40, #3 Formula 40, #5 GTU, #10 Middleweight GP
2016 Middleweight F40 Track Champion, #3 Formula 40, #3 Middleweight F40, #8 Middleweight GP
2016 Sportsmanship Award, 2015 Crash & Burn Award, 2014 Sportsmanship Award, 2013 Amateur of the Year
#132 Proudly representing DC-Moto.net,
, and
The Evil Twin is offline
post #8 of 9 (permalink) Old 05-07-2019, 05:05 PM Thread Starter
Betan's Avatar
Hello, so I got the radiator cap replaced and it's working great no more leak. Thanks for all the help.
Betan is offline
post #9 of 9 (permalink) Old 06-10-2019, 09:49 PM Thread Starter
Betan's Avatar
Hello, has anyone one of you guys used a a higher rated radiator cap? Eg: from 1.1 to 1.4.
Betan is offline
Cant Find Coolant leak Origin r6Ben00 Garage / Mechanical Help 8 03-29-2019 05:17 PM
2001 YZF-R6 pinched fuel hose 2JZFRSH Exhaust and fuel delivery 0 02-19-2019 07:30 AM
2007 r6 burned hose bmoyer New Member Section 2 12-14-2018 10:48 AM
coolant coming off bike like a waterfall r6Ben00 Garage / Mechanical Help 7 07-02-2018 10:34 AM
What coolant do you guys use R6_Dude General Discussions 6 08-02-2004 08:18 PM
