Bike Isnt Running Right - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 6 (permalink) Old 05-14-2019, 06:47 PM Thread Starter
Hey guys, I have an Ď08 R6 with about 15k miles on it. The other day while I was riding home from work I was stopped at a light and suddenly my idle changed, I lost 80% of my power, and it sounds like a dirtbike. Iíve replaced the spark plugs, and the coils work fine. Iím out of ideas. Anyone have any clue?
Colton Laidig is offline
post #2 of 6 (permalink) Old 05-14-2019, 06:49 PM
Parts Pimp
ChiefSmokeDawg's Avatar
Bike: 2002 R6, 2008 R6
Re: Bike Isnt Running Right
If you think itís not running on all four cylinders, let it idle. Spray water on the header tubes. See which one/ones are cold. Swap the coils from the good ones to the cold cylinders and see if the issue follows the coil.
ChiefSmokeDawg is offline
post #3 of 6 (permalink) Old 05-14-2019, 06:51 PM Thread Starter
All of the coils are sparking though? I tested all of them with one of the new plugs I bought.
post #4 of 6 (permalink) Old 05-15-2019, 03:56 PM
Bike: 2015 R1
Garage
Do what he said. it's the best way to test the coils. sometimes they can arc to the valve cover and cause a misfire.
yamahacrazy is offline
post #5 of 6 (permalink) Old 05-17-2019, 09:01 PM
Reading ohms/resistance on my coils wasn't helpful. But we're talking a tiny .08 range in primary coil specification when all of your volt meters only read down to tenths of an Ohm, rather than Hundredths. I was able to spot my "bad" one by using a spark gap tester. Adjusted out to a HUGE gap, I was able to see that one wasn't able to consistently/reliably fire at the same gap that the other three did. They performed the same on all four wires, so I knew it wasn't the wire harness or the ECU.
Intuit is offline
post #6 of 6 (permalink) Old 05-18-2019, 08:04 AM
Bike: 2015 R1
Garage
there's a company that makes an awesome ignition test system but it's very expensive. but I want it anyway.
and they have the best synchronizer on the market
both of these would set a mechanic back $1000 though.
2016 R6 Wont Stay Running (Sometimes) septantrionalis General Discussions 5 03-19-2019 07:01 PM
'05 Cold start / 2k-6k running rough issues bandaidPRO Garage / Mechanical Help 3 12-31-2018 11:41 AM
euro running lights udh2oskier Appearance and Exterior Mods 20 10-02-2004 12:07 PM
Running Light / Flasher Opinions Yogi Appearance and Exterior Mods 1 08-07-2004 10:12 AM
LP Flush Mounts Installed Now I have No Running Lights R6-Rider07 Garage / Mechanical Help 4 06-12-2004 06:26 PM
