2005 R6 not firing in cylinders 1 and 3 - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 5 (permalink) Old 05-23-2019, 10:00 AM Thread Starter
Spent a long time isolating a charging issue (turned out a cheap stator that I replaced was no good so ended up with an oem that worked) but when I finally got the bike charging properly cylinder 1 and 3 were not firing. My thoughts were bad coils so I swapped cylinder 2 and 3 coils and it didn’t fix the issue, and then spark plugs (needed to be replaced anyways so I redid them all) still not firing in cylinder 1 and 3, so I thought CDI unit but from what I have found the CDI controls cylinders 1&2 independent of 3&4, which makes me think it’s not that since cylinders 1 and 3 are the ones misfiring and I don’t want to waste $200 on a new CDI unit if I don’t have to. Which makes me think something happened to the fuel system in the process of diagnosing my charging system since I had to take the fuel tank on and off several times, but what would cause cylinders one and three not to fire? Any info or suggestions would be much appreciated!
zR6fang is offline
post #2 of 5 (permalink) Old 05-23-2019, 04:59 PM
Bike: 2015 R1
Garage
There's no such thing as a cdi on a 2005 r6
yamahacrazy is offline
post #3 of 5 (permalink) Old 05-23-2019, 07:00 PM
Had the same issue, make sure your fuel lines that connect to your tank and injectors are snapped on and completely tight.
NotNattyR6 is offline
post #4 of 5 (permalink) Old 05-24-2019, 11:43 AM Thread Starter
NotNattyR6 Is there any good way to tell if they’re on propeperly? I took the hose off yesterday that connect from the rail to the pump and made sure the O Ring inside wasn’t kinked, snapped it together tight and still only running on 2 cylinders. Any suggestions?
zR6fang is offline
post #5 of 5 (permalink) Old 05-24-2019, 04:48 PM
Bike: 2015 R1
Garage
Re: 2005 R6 not firing in cylinders 1 and 3
you can test the injectors in diagnostic mode. do you have a service manual? you can download it here,
in chapter 7 the fuel injection chapter, it shows you how to get into and use diagnostic mode.
2005 Yamaha R6 - Full Part Out San Carlos, CA - 94070 jabutler_166 Bike Parts For Sale 7 06-10-2019 04:16 AM
Steering damper fitment for 2005 R6 chipmunk Suspension settings 5 03-27-2019 06:44 PM
FS: 2005 R6 Stock & Aftermarket Parts - Ohlins, Akrapovic, Brembo, Shark Skinz & More teubank49 Bike Parts For Sale 15 03-20-2019 07:07 AM
