How to increase idle 2018 R6 - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 5 (permalink) Old 05-26-2019, 05:40 AM Thread Starter
2018HaydenR6's Avatar
Bike: 2018 R6
Hi guys, I have flash tune software and I am looking to raise my idle by 200-300rpm, does anyone know what setting I have to adjust in the software?
2018HaydenR6 is offline
post #2 of 5 (permalink) Old 06-02-2019, 03:21 PM
Re: How to increase idle 2018 R6
Hayden, Did you ever get your FTECU working? I would send this in a private message but this forum has a billion rules LOL
LiquidAreSix is offline
post #3 of 5 (permalink) Old 06-03-2019, 09:14 AM Thread Starter
Bike: 2018 R6
Yeah it’s working, I am trying to increase my idle by 100-200rpm as it is rough with the exhaust I have on. I ride the occasional track day but this is more of an issue on the street. Let me know if you know what setting I need to adjust in my FT software.
Thx
post #4 of 5 (permalink) Old 06-03-2019, 06:26 PM
Bike: 2015 R1
Garage
Thx
who's maps are you using? it matters because for example graves maps may not allow it.
in the unrestricted maps this is how,
you navigate to the idle speed folder on the left of the screen. (collapse all the trees first) then it's under ECU mapping. then click on the warmup / base idle folder. below that, click on ECT vs RPM idle speed. this is the map you will adjust. once open study it for a second. notice along the top is the Engine Coolant Temp. down the left side is the engine RPM. in the green areas after the engine is hot is where I think you need to raise from 00. I believe these numbers are the throttle angle. notice after the red blocks you have one in orange and it's 2.46. I would think that if you went from .00 in the green to .5 or 1 it will raise the rpm what you want. I wouldn't think you need to adjust anything above 1450 rpm. the bike should idle around 1350 stock.
flash the ecu and see how it idles. adjust it until you're happy. I've never played with these settings to be honest but I believe this is how you do it.
yamahacrazy is offline
post #5 of 5 (permalink) Old 06-03-2019, 06:58 PM Thread Starter
Bike: 2018 R6
Awesome thanks, I will give that a shot. I’m using unrestricted map with auto tune.
2018 R6 Matte Gray - Supersport 600 Conversion rusky Bike Build Forum 23 09-07-2019 12:46 PM
07 R6 idle and cold start problem Jonathan Zhao Garage / Mechanical Help 2 04-24-2019 12:02 PM
2006 r6 idle jumping when warm datr6guy Garage / Mechanical Help 0 02-18-2019 06:21 PM
2003 R6 low idle after bike heats up Luke Dixon Garage / Mechanical Help 8 12-19-2018 12:00 PM
06 r6 rough idle and bogging/stuttering at takeoff ccsencsits Garage / Mechanical Help 0 07-15-2018 03:06 PM
