Overheating Issue - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 14 (permalink) Old 06-04-2019, 04:09 PM Thread Starter
Overheating Issue
My bike is overheating! Temps getting up to 240!!!! Fans are turning on at 210 but it doesn't help. Doesn't cool down even when moving. thermostat is good. New radiator cap. No blockage in teh radiator. I then noticed a small water drip coming from the oil pan! Oil looked ok. Is it possible I have a bad head gasket? any other ideas?
nytrozula is offline
post #2 of 14 (permalink) Old 06-04-2019, 04:24 PM
2018HaydenR6's Avatar
Bike: 2018 R6
I would drain some of the oil out and look for a white milky substance in it. Fingers crossed it’s not that.
How many km on the bike?
2018HaydenR6 is offline
post #3 of 14 (permalink) Old 06-04-2019, 04:56 PM Thread Starter
Re: Overheating Issue
already drained the oil and it looks good. I have a leak at the thermostat. I don't see a gasket on the cover or in the parts diagram. should there be some type of sealant on this cover?
post #4 of 14 (permalink) Old 06-04-2019, 04:58 PM
Bike: 2018 R6
what year bike is it, i'll try to find some info.
post #5 of 14 (permalink) Old 06-04-2019, 05:16 PM Thread Starter
Its an 08. The drip at the oil pan is of course from the leak at the thermostat! I panicked and thought the worse! Why the hell is the water not cooling down? Bad radiator?
post #6 of 14 (permalink) Old 06-04-2019, 06:00 PM
Why yes I don't!!!!!!!!!!
TurboBlew's Avatar
Bike: 2007 In Heaven
did you pressure test the cooling system??? Real easy to tell if the headgasket is holding. 2008... did you check your waterpump impeller?? They go bad
TurboBlew is offline
post #7 of 14 (permalink) Old 06-05-2019, 06:37 AM Thread Starter
I pulled the cover on the water pump and checked the blade and that it spun freely. No issues there. I guess pressure testing the cooling system will be next. If head gasket was bad shouldn't I see this in the oil? Or coolant bubbling?
post #8 of 14 (permalink) Old 06-05-2019, 07:54 AM
TurboBlew's Avatar
not necessarily. The pressure test is to see if there is a way for air to enter.
Could be a bad clamp, cracked jacket, or broken over flow. Im gona bet a small crack.
post #9 of 14 (permalink) Old 06-05-2019, 08:16 AM Thread Starter
small crack? where? in the block? Is a pressure test going to detect this? And would this be the reason the bike is overheating so badly?
post #10 of 14 (permalink) Old 06-05-2019, 01:25 PM
TurboBlew's Avatar
A pressure test will determine IF your cooling system can hold pressure.
If you add pressure to the system... let it sit overnight it should be the same in the morn. The system has to be full of fluid.
You could have a small crack in the water jacket. Seen this happen on a race bike. Basically it will weep a small amount. You could have a failing hose. You could have a bad water pump... lots of things. Might take a good flat rate guy about 2hrs to figure out.
