Why are there holes drilled in engine block? - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 8 (permalink) Old 06-21-2019, 10:48 AM Thread Starter
davyk85's Avatar
Anybody any ideas why somebody would have drilled holes in an engine case? Just noticed these and wondering if anyone has any idea about it
davyk85 is offline
post #2 of 8 (permalink) Old 06-21-2019, 05:34 PM
Bike: 2015 R1
Garage
Re: Why are there holes drilled in engine block?
it's factory. no I don't know what they're for. possibly an assembly reason.
yamahacrazy is offline
post #3 of 8 (permalink) Old 06-21-2019, 10:01 PM Thread Starter
davyk85's Avatar
That's good I thought the previous owner might've done it as I was looking at some used engines on Ebay and couldn't see any holes on those.
davyk85 is offline
post #4 of 8 (permalink) Old 06-22-2019, 05:14 AM
Why yes I don't!!!!!!!!!!
TurboBlew's Avatar
Bike: 2007 In Heaven
whaaa??? What sand cast cases have rando holes formed in them??
Easy fix but factory? I dont think so.
TurboBlew is offline
post #5 of 8 (permalink) Old 06-22-2019, 08:30 AM
The reverse side of those holes are flared. If they were a little lower I'd speculate water drain. YC is right, they're factory.
Intuit is offline
post #6 of 8 (permalink) Old 06-22-2019, 01:26 PM
Bike: 2015 R1
Garage
lol they're machined holes obviously. castings can have holes. it called cores. trust me, I worked making molds for the casting industry for 6 years. how do you think they get all the coolant jackets in the head and block?
I was saying maybe there in that spot so the robots can pick it up etc. or it's so they can sit on a stand the way they need it. im 99% sure mine had them also. intuit can tell us. he has the same bike
here is how it works,
post #7 of 8 (permalink) Old 06-23-2019, 05:31 AM
TurboBlew's Avatar
from the looks of the pic seems to be on the back side of the engine in the transmission area and not very cleanly bored. Cant say Ive ever seen holes done like that. Weep holes for water? Again never seen anything like that on a stock casting.
post #8 of 8 (permalink) Old 06-23-2019, 06:44 AM
Mine has them. Contrary to assumptions, these aluminum alloys do degrade, but it shows as white powdery splotches; and that's what we're seeing in the photos.
The side he photographed is flat, but the other side is flared, like these.
It opens up to the area beneath the seat, so the amount of corrosion is minimal; looks clean as opposed to the other side. It may be that corrosion that gives the OP's photograph the rough "drilled" look. Based on the other side I doubt they're machined; though it's still perfectly possible.
Maybe they stuck wires through these holes for hanging them up while dipping them or something?
Intuit is offline
