Manually Controlling Radiator Fans - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 8 (permalink) Old 07-15-2019, 12:34 PM Thread Starter
parkypine's Avatar
Gents/ladies, got a question about wiring up fans to turn on manually on my 08.
++ Disclaimer ++
My 08 track bike heat soaks a lot after coming off the track (regularly see 220+ with fans running wild, doesn't exceed 227 from what i can tell). On the track, it stays around 180s~190s, normal operating range. By no means do I think operating temp is the issue, but I would like to mitigate the heat soak so I can shut my bike off in peace.
++ Logistics ++
If I had a way to manually control the radiator fans, I would flip the switch as I am coming off the track in anticipation of the temp jumping. The bike currently does not have a highbeam/lowbeam switch stalk, so I figured I can use that for fan on/off switch.
The way I understand is that the ECU sends a 12v signal to the fan relay which turns the fans off. I would like to keep this automatic fan control setup just in case the bike shoots past 214F without me noticing.
My thought was to take the light switch, figure out which wires are for highbeam (since lowbeam is on all the time), then connect the highbeam wire directly to the ECU signal wire.
Logic behind wiring up highbeam switch to fan relay WHILE keeping the ECU signal intact is so that I can switch the fans on prematurely & manually, while keeping the automatic fan function for safety.
Has anyone done this before? Tried searching the forums right quick but no luck. Any input and/or correction of logic/knowledge is greatly appreciated!
PFA - my ugly duckling
parkypine is offline
post #2 of 8 (permalink) Old 07-15-2019, 05:04 PM
Bike: 2015 R1
Garage
Re: Manually Controlling Radiator Fans
you can flash the ecu to have the fans come on sooner.
yamahacrazy is offline
post #3 of 8 (permalink) Old 07-18-2019, 10:36 AM
Knee drags YOU!
Panici's Avatar
Bike: '05 R6 + Vintage Yamahas
Images: 1
I'm not familiar with the ECU output, but I'd have a diode in front of the ECU, so you're not sending voltage back into it from the highbeam circuit.
Mods: Armor Bodies Superbike bodywork, Pirelli SBK Pro Slicks, Renthal 50mm Clipons, Bickle warmers, etc, etc...
Gear: ATGATT down to the mouthguard.
A few vintage Yamaha bikes
Panici is offline
post #4 of 8 (permalink) Old 07-18-2019, 11:37 AM
nova r6
tdoss1980's Avatar
Bike: 05 r6 Camo/Orange
When the bike "heat soaks" are you leaving it running while sitting in the pits and the temp comes up to what you are describing or are you leaving the ignition on and hitting the red kill switch to leave the electronics on and that is when you see the temp rising and the fans keep running?
March 2014 Bike of the month
tdoss1980 is offline
post #5 of 8 (permalink) Old 07-19-2019, 02:30 PM
Why yes I don't!!!!!!!!!!
TurboBlew's Avatar
Bike: 2007 In Heaven
run a parallel switch. Real easy to turn fans on/off at will.
TurboBlew is offline
post #6 of 8 (permalink) Old 07-21-2019, 01:50 AM
Originally Posted by Panici View Post
I'm not familiar with the ECU output, but I'd have a diode in front of the ECU, so you're not sending voltage back into it .......
^ This makes sense.
Because I'm not personally confident in the reliability of some diodes, (if it fails open, it then prevents the ECU from signaling the relay,) I'd probably go the safer route of adding an independent relay with inline fuse. (the add-on switch's power could be sourced from the lighting circuit) Having 12v simultaneously supplied to the fan by both of the relays would be inconsequential.
Intuit is offline
post #7 of 8 (permalink) Old 07-21-2019, 07:20 AM
Bike: 2015 R1
Garage
I would leave the shit how yamaha engineers designed it and send the ecu off to be flashed with custom fan on/off temps. and a host of other settings they can do at the same time. you burn that ecu up with hacked wiring you're looking at $800 to 1200 for a new one.
post #8 of 8 (permalink) Old 07-21-2019, 11:39 AM
That's the benefit of having an independent relay. You're not modifying or potentially interfering with the existing circuit between the ECU and relay.
Intuit is offline
