08 R6 start but won’t move - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 5 (permalink) Old 07-22-2019, 05:08 AM Thread Starter
I have a 2008 R6 was riding perfect yesterday then it just stop accelerating. Bike revs but just won’t move.
When I release the clutch in first bike don’t even stall out, shift to second nothing.
Attach a pic of my front sprocket
File Type: jpg CAA89FCE-43CA-4515-B4B6-E662176DE0B3_1563797299388.jpg (96.8 KB, 17 views)
Prezzidon is offline
post #2 of 5 (permalink) Old 07-22-2019, 12:55 PM
Re: 08 R6 start but won’t move
Put the rear wheel up on the air on a stand. Does the wheel move in 1st, Neutral or 2nd?
Intuit is offline
post #3 of 5 (permalink) Old 07-22-2019, 02:46 PM Thread Starter
Yes it doesn’t move in first gear
post #4 of 5 (permalink) Old 07-23-2019, 09:34 AM
It's in neutral. This has nothing to do with the sprockets/chain.
The gears aren't engaging. Check clutch (make sure the friction point isn't set too close to the bar), check clutch line all the way to the engine block, making sure it is not loose which would indicate the wire is broken or just adjusted too loose. Check your gear shifter, make sure it's actually engaged to the teeth on the part that sticks out of the engine (I forget what the part is called). You should hear and feel a clunk when a gear is engaged.
Cbrsmurf is offline
post #5 of 5 (permalink) Old 07-23-2019, 11:34 AM
Engine off, repeat the above test but instead, try rolling the wheel by hand. Any movement in First, Neutral and Second?
Intuit is offline
