2007 r6 carb removal, help needed - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 7 (permalink) Old 08-25-2019, 06:35 PM Thread Starter
flicks & clutch ups
brando loudly's Avatar
Bike: 2007 YZF R6
hey guys. im replacing my wiring loom after troubleshooting forever and being unable to find a short. the old loom is in pretty bad shape.
i need to know how to remove my carbs to get my look out and the new one installed. i have the air box off. here's what im looking at in the manual and some pics of my bike. any help is appreciated
i've loosened the 4 screws at the bottom represented by the number 4 in the diagram. im not sure if im just supposed to muscle it out or what. thanks again in advance
2007 YZF R6
brando loudly is offline
post #2 of 7 (permalink) Old 08-26-2019, 05:11 AM
Flyers28's Avatar
Bike: 07 Candy Red R6
Re: 2007 r6 carb removal, help needed
For starters its the throttle body. No carbs on this bike. But semantics.
Muscle it out. It's just stuck to the boots. Wiggle as you pull. Just be careful what you're pulling on. Try and only grab the main throttle body.
Flyers28 is offline
post #3 of 7 (permalink) Old 08-26-2019, 06:52 AM
Freemaysin's Avatar
No carbs this bike is fuel injected, those are your 4 throttle bodies. They can be a pain but as long as you have all bolts out, and sensor plugs/hoses disconnected it just takes a little extra effort to pull them out.
The rubber has just been in there since factory and its holding like a gasket.
As far as your 3rd pic looks, you should be able to grab 1 side, lift up on it, then the rest will come with it out and at an angle. If you try to grab each side and pull directly up, the suction of the boot is gonna work against ya!
If you've gotten this far, you're good tho
Freemaysin is offline
post #4 of 7 (permalink) Old 08-26-2019, 07:19 PM
TyroneElGoat's Avatar
Bike: 2007 R6
I replaced my main harness a couple of months ago too. I just rocked em out after I loosened the screws. I didn't end up taking off the throttle cable though, just left em up on end while I put in the new harness. Good luck!
TyroneElGoat is offline
post #5 of 7 (permalink) Old 08-27-2019, 06:21 PM Thread Starter
flicks & clutch ups
Bike: 2007 YZF R6
thanks guys. got the harness replaced..... and the fuel injection fuse still blows! lmao. im very lucky like that. any ideas?
2007 YZF R6
post #6 of 7 (permalink) Old 09-02-2019, 11:24 AM Thread Starter
flicks & clutch ups
Bike: 2007 YZF R6
It was a short at the base of my o2 sensor
2007 YZF R6
post #7 of 7 (permalink) Old 09-04-2019, 04:47 PM
Bike: 2015 R1
Garage
I was going to suggest dynamite.
yamahacrazy is offline
