FS: 2005 Yamaha R6 - Full Stock & Aftermarket Part Out - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 17 (permalink) Old 04-10-2019, 11:57 AM Thread Starter
jabutler_166's Avatar
Bike: 2006 R6
Updated with Photos
2005 Yamaha R6 - Full Part Out
San Carlos, CA - 94070
May Ship - Talk me into it...
FRAME, SUSPENSION & CONTROLS
- Stock Forks - 150.00
- Stock Rear Shock - 75.00
- GPR Steering Damper w/ Tripple clamp bracket - $115.00
- Frame - 2005 Yamaha R6, comes with Bill of Sale - $300.00
- Rear Subframe w/ Plastic Tray - oem - $200.00
- Aluminum Race Upper Fairing Stay - $50.00
- Rear Sets L/R Footpeg Brackets w/ Brake & Shift Levers & Mount Bolts - 115.00
- Upper & Lower Triple Clamps w/ Bearings - $100.00
- Billet Race Clipon Handlebars - L/R- $135.00
- Throttle Housing Assembly w/ Tube & Cables - $25.00
- Swingarm w/ Rearstand Spools, Pivot Bolt, Rear Axle & Chain Adjusters - $75
- Clutch Perch w/ Lever & Cable - 20.00
ENGINE COMPONENTS
- Engine - 2005 Yamaha R6 8450 miles, good-running condition - sold
- Akrapovic Full Exhaust System - includes all mount hardware - 200.00
- Radiator w/ rubber tubes - oem - $75.00
- Throttle Bodies w/ Injector Harness - oem - injectors need cleaning - $75
- Air Intake Runners set (front to airbox) - oem - $15.00
- Airbox w/ Air Filter - $20
BRAKES & WHEELS
- Stock Front Brake Master Cylinder w/ Lever, Reservoir - $100.00
- Front Brake Lines Steel - 25.00
- Front Stock Brake Calipers w/ Pads L & R - oem - $50.00
- Rear Brake Caliper w/ Pads & Mount Bracket - oem - $25
- Rear Brake Master Cylinder w/ Reservoir & Brake Line - oem - $25
BODYWORK
- Race Fairing Set - rashed out - lots of scratches - includes upper fairing, lower fairing, tail fairing, front fender and fairing fasteners - $100.00
- Gas Tank - black paint, some rust, no dents, normal wear & tear - $125.00
- Stock EOM Gas Cap - $20
- Seat - oem -small rip - $10.00
ELECTRICAL COMPONENTS
- ECU - stock - sold
- Power Commander PCIII - sold
- Fuel Pump Assembly w/ Mount Flange - oem - $100.00
- Dash - showing 8425 miles - $140.00
- Main Wire Harness - looks like it has all the oem plug ends for the street gear, plugs for fuel pump must be repaired - $50
- Ignition Coils - Set of 4, w/ Coil Harness - $85
- Right Hand Switch - Start/Kill Switch - $20
- Voltage regulator - oem - $30.00
ID:	360704   Click image for larger version
ID:	360706   Click image for larger version
ID:	360708   Click image for larger version
ID:	360710   Click image for larger version
ID:	360714   Click image for larger version
ID:	360716   Click image for larger version
ID:	360718   Click image for larger version
ID:	360720   Click image for larger version
ID:	360724   Click image for larger version
ID:	360726   Click image for larger version
ID:	360728   Click image for larger version
ID:	360730   Click image for larger version
ID:	360734   Click image for larger version
ID:	360736   Click image for larger version
ID:	360738   Click image for larger version
ID:	360740   Click image for larger version
jabutler_166 is offline
post #2 of 17 (permalink) Old 04-10-2019, 12:03 PM Thread Starter
Bike: 2006 R6
re: FS: 2005 Yamaha R6 - Full Stock & Aftermarket Part Out
More Photos:
ID:	360744   Click image for larger version
post #3 of 17 (permalink) Old 05-09-2019, 02:07 PM
Do you have the a headlight fairing and bulbs?
TheU is offline
post #4 of 17 (permalink) Old 05-12-2019, 03:26 AM
Greetings. I am interested in Fuel Pump Assembly w/ Mount Flange - oem - $100.00. Unfortunately, I can't send you a PM because I don't have enough posts... (but I've been a member for over 10 years!). I am in Burke, VA 22015 and would really appreciate a ship please. Thanks! I can also be reached at woolyhatkat @ gmail.com. Thanks!
- Woolly
woollyhatkat is offline
post #5 of 17 (permalink) Old 05-12-2019, 11:53 PM Thread Starter
Bike: 2006 R6
sorry - sold
post #6 of 17 (permalink) Old 05-19-2019, 10:02 PM
Are you willing to ship full exhaust to Alabama?
MDH4UA is offline
post #7 of 17 (permalink) Old 05-26-2019, 08:05 PM
Do you still have the front brake calipers? And can you ship to Louisiana?
nbrewer4703 is offline
post #8 of 17 (permalink) Old 06-21-2019, 01:28 PM
Lets make a deal on the gauge cluster, brake master, and steering damper! pm me
TheU is offline
post #9 of 17 (permalink) Old 06-24-2019, 11:55 AM
Re: FS: 2005 Yamaha R6 - Full Stock & Aftermarket Part Out
Im not sure what you have left but I could use the right side rearset, the clutch perch, the air intake tubes and the seat. pls let me know. Gene Hopkins 916 509 6418 thx
theairguy is offline
post #10 of 17 (permalink) Old 06-27-2019, 12:56 AM
Looking to bundle the clipons/levers, full exhaust, steel break lines and the steering stabalizer if its still around give me a call or a text 6364260594 or email me
Interested in a few other odds and ends too. reach out to me with what you still have and we'll make a deal.
Bryce1552 is offline
FS: 2009 R6 Stock Part Out John Orchard Bike Parts For Sale 69 08-13-2019 01:09 AM
2008 R6 Full Part Out Sonofsam Bike Parts For Sale 31 02-17-2019 09:17 PM
