Front brake lever adjustment???? - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 5 (permalink) Old 07-22-2006, 02:30 PM Thread Starter
Clerks 2 IS cool
R6ed's Avatar
Bike: 02 R6
Send a message via Yahoo to R6ed
Ok I am really not stupid,
I have owned an R6 now for about 4 years. I am a mechanic (helicopter). Ok here is my question, On the front brake lever there is an adjustment 1-5, What does this affect? I have asked numerous people around here that ride and they all give me different answers. Also what would be the best number to have it set on. Thanks
R6ed is offline
post #2 of 5 (permalink) Old 07-22-2006, 02:39 PM
js05r6's Avatar
Bike: 2005 R6
well im not sure about your bike, but on an 05 the nob as like 3 settings, and all it does is adjust the position of the lever
js05r6 is offline
post #3 of 5 (permalink) Old 07-22-2006, 03:38 PM
BEEFY!
ShortyR6's Avatar
Bike: 05 R6 track, 06 R1 street
Send a message via AIM to ShortyR6 Send a message via Yahoo to ShortyR6
it will adjust how far out you want the lever. i keep mine close since i have short fingers, but you can adjust it to your liking.
ShortyR6 is offline
post #4 of 5 (permalink) Old 07-22-2006, 04:41 PM
MK33's Avatar
Bike: Red 04 R6
yep, just adjusts how far or close the actual lever is
MK33 is offline
post #5 of 5 (permalink) Old 05-13-2019, 12:06 PM
I <3 Orange Chicken
Detrich's Avatar
Bike: 2010 YZF-R6 - Blue
Re: Front brake lever adjustment????
Does adjusting the lever's distance from the throttle also change the point where the brake engages? And, which direction of the bolt adjustments makes it wider and which one closer to the throttle?
I would like the front brake to engage earlier with less pull of the lever, so that it's easier to trail brake with just 2 fingers. I'm happy with the distance the lever currently sits from the throttle. So, I'm confused as to whether adjusting the lever's distance from the throttle will achieve what I need it to do. If I'm facing the lever, and I turn the bolt to the right, will that make the lever close to the throttle and engage the brake sooner?
If I make the lever too close to the throttle, then it squishes my right-hand's ring finger and pinky, since I only brake with my index and middle finger. Right now, the engagement point is too long- meaning that the brake lever almost has to be fully pulled in for me to feel the brake is engaging. It's not good for trail braking. I need the brake to engage at about 1/2 way point of the lever being pulled.
Does the brake line tension have to be adjusted to achieve what I want to do?
Thanks.
2010 Yamaha YZF-R6 - Blue [4.09.2011] - GYTR CF Heel Trim, ProGrip CF Tank Pad, Shogun NC Crash Kit, Yamaha White Seat Cowl, GPR v4 Steering Damper
2012 Yamaha YZF-R1 - Blue [3.30.2013] - GYTR CF Heel Trim, ProGrip CF Tank Pad, Shogun NC Crash Kit, Yamaha White Seat Cowl
2009 Yamaha FZ6R - Blue [1.23.2010 - 3.10.2012 Sold]
Detrich is offline
i'm impotent =( deltaonex General Discussions 43 01-06-2012 09:23 AM
high side?? nybimmer General Discussions 22 03-09-2008 07:50 AM
HELP! Brake lever holder broke! 69z28lt1 General Discussions 3 07-19-2006 06:42 PM
how to bleed front brake warsatan Garage / Mechanical Help 3 03-06-2006 01:35 PM
Front brake lever activating brake light... s4isccol General Discussions 6 03-07-2005 07:50 AM
