How to install the Power Commander III - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 61 (permalink) Old 12-09-2006, 03:46 PM Thread Starter
maxoverfred's Avatar
How to install a Power Commander III (R6 2006)
Very easy tutorial: installation of the Power Commander III USB.
You will need to access the under the tank, so just remove the tank from his original place.
Remove the plastic fairing below the tank and move the tank. Find a solution to have a complete access to the airbox.
Remove the seat and move slightly the ECU box in order to have move place to work. The PC will be fixed with velcro on the ECU box.
The following are screenshots from the original documentation (because it's nicely done).
Some pictures of the installation on my bike:
USB connection:
If you connect your laptop by USB, be sure that the USB is correctly plugged in (need to help a little bit to have it plug correctly). The current map will be directly displayed in the software provided with the PC. To load a map, just send it and you will get a confirmation when it's loaded. Use the throttle and see the synchro within the program on your laptop.
External power required to run a PCIII:
The Power commander requires external power in order to communicate with it or to make button adjustements. On some models of motorcycles, power is only supplied to it while the engine is running (if the lights on the face of the unit go out a few seconds after switching on the ignition: your bike is affected by this); To power the PCIII you can connect the supplied 9 volt power adpater instead of using the bike's power. (extract from the original documentation)
Video:
maxoverfred is offline
post #2 of 61 (permalink) Old 12-09-2006, 08:28 PM
Re: How to install the Power Commander III
good post!
disnigkais4rlz is offline
post #3 of 61 (permalink) Old 12-10-2006, 04:14 AM Thread Starter
Thanks, post updated with a short video.
post #4 of 61 (permalink) Old 12-10-2006, 05:55 PM
i have a question i put in my power comander on my 06 50th and i followed the directions that were given. although the power commander does not seem to be powering up with the bike on and i have to put the battery hook up on the power commander to get it going. im wondering what part of the hook up did i go wrong or do i need to like charge the power commander for a certain amont of time. im not sure about this so any help would be awesome thanks.
kgstyle10 is offline
post #5 of 61 (permalink) Old 12-11-2006, 07:21 AM Thread Starter
You are right, the power commander doesn't work on itself, it need to be on a charger (9volts - the adapter is provided with the PCIII) or you need to start your engine to aliment your PC.
I will complete my post with this short and useful notice.
post #6 of 61 (permalink) Old 12-11-2006, 03:22 PM
yea thanks man i am running the 9 volt right now but it just sucks that i have to plug and unplug that thing everytime i go riding it just doesnt make sence u know
post #7 of 61 (permalink) Old 12-11-2006, 06:15 PM
freezer16801's Avatar
Bike: 03 R6-track 02 TLR-street
you don't need to plug in the 9 volt for it to turn on. Your motorcycle should power it. You did something wrong if it doesn't work with just the motorcycle power.
"All looking to make their mark, to be feared and to be loved."-Mario Puzo
Nesba "I" #727, TPM "Red", sportbike track time "I"
03 track bomber: 97 cent walmart rattle can sharkskins, graves fairing stay, woodcraft rearsets and gp shift, 520 kit, vortex clipons, super flares, bmc race, pcIII usb w/ custom map, +4 ignition advance, slide stops, no ais, micron, 05 radial master cylinder, steel lines, vesrah pads, motul race fluid, racetech fork internals, ohlins triple rear, ohlins steering damper.
future upgrade: learn to ride
freezer16801 is offline
post #8 of 61 (permalink) Old 12-11-2006, 08:45 PM
thats what im asking where i went wrong
post #9 of 61 (permalink) Old 12-11-2006, 08:59 PM
Mine is an 03. It was pretty simple. I hooked the black harness up to the bikes black and the other one up to its equivalent harness. And then I hooked up the ground to the ground on the battery terminal. You know that the power commander itself won't have any lights on at all while it is running? What makes you believe that the power commander isn't working?
post #10 of 61 (permalink) Old 12-12-2006, 08:34 AM
nice write up i will be using it soon as i already ordered mine!
jgny2000 is offline
06-07 R6 POWER Commander PC3 USB install... SpidermanSS Exhaust and fuel delivery 111 06-09-2019 01:45 PM
Power commander rocks unknown_host Exhaust and fuel delivery 7 08-29-2006 05:07 PM
Any of you actually dyno after power commander install? BaileyMotorSports General Discussions 3 07-28-2006 07:35 PM
Power Commander install problems blueloulou Product Reviews 12 05-30-2004 01:11 PM
quick shift power commander dj1298 Exhaust and fuel delivery 2 12-31-2003 04:22 PM
