How To: DIY YEC Interface Cable For $25 or less. - Page 3 - Yamaha R6 Forum: YZF-R6 Forums
 1Likes
post #21 of 40 (permalink) Old 08-26-2017, 04:40 AM Thread Starter
Nz08R6's Avatar
Bike: 2008 R6
Garage
Re: How To: DIY YEC Interface Cable For $25 or less.
Thanks Benjamin I glad it's working out for you.
If anyone wanting to make one of these is'nt sure just send me a message or posting here would be more beneficial to others and I will help you out the best I can. There are loads of different converters and cables on the market some are easier to get working than others due to driver issues and knock off chips etc but I'm happy to help I'm not very active on here these days but will reply eventually haha.
Make your own YEC Interface cable
Nz08R6 is offline
post #22 of 40 (permalink) Old 08-26-2017, 05:39 AM
Pmed
Jpence is offline
post #23 of 40 (permalink) Old 08-26-2017, 05:41 AM Thread Starter
Nz08R6's Avatar
Bike: 2008 R6
Garage
Originally Posted by Jpence View Post
Originally Posted by Nz08R6 View Post
Send me a pm I can send you a base map
Please send me base map
Sent from my SAMSUNG-SM-G935A using Tapatalk
What year is your bike?
Nz08R6 is offline
post #24 of 40 (permalink) Old 11-29-2017, 10:59 PM
Hello,
I have follow the instructions but it doesnīt work for my R6 2010.
I tryed whit this cable, who has the 5V logic level and ledīs to see the Rx and Tx transfer: Gearmo USB to 5v TTL Header Like FTDI TTL-232R-5V
I swaped the Rx + Tx signals but the software canīt read something from the ECU. At the converter I only see for one second some lights. Driver is installed correctly.
Do I have to connect the CTS signal to the ground? Could it be that I have to look which modell of Yec ECU I have, maybe I use the wrong basemap file on my software?
Thanks in advance
Clockben is offline
post #25 of 40 (permalink) Old 11-29-2017, 11:06 PM Thread Starter
Nz08R6's Avatar
Bike: 2008 R6
Garage
Originally Posted by Clockben View Post
Hello,
Thanks in advance
Connect the cts to ground some cables I have used needed that to work. And others don't.
Give it a go let me know if it works.
The base map doesnt matter to much as long as it's 08+ cause when you read from the ecu it overwrites all the tables with what is in the ecu.
Nz08R6 is offline
post #26 of 40 (permalink) Old 12-01-2017, 12:41 AM
Works fine now. I have connect the cts to the ground.
Thank you my friend !
Clockben is offline
post #27 of 40 (permalink) Old 05-07-2018, 06:25 AM
R6 Track Bike
Bike: Yamaha R6 2016
Great thread,
I bought the board and soldered the wires.
The USB Driver loaded fine.
However, when I connect the cable and try to read the ECU it simply says...
"No response from ECU"
there is a flash of light on the board but thats all.
I then, connected the CTS wire to ground and tried that...
Any Ideas??
Your help would be greatly appreciated.
Gavin
1berts is offline
post #28 of 40 (permalink) Old 05-07-2018, 12:20 PM Thread Starter
Nz08R6's Avatar
Bike: 2008 R6
Garage
Originally Posted by 1berts View Post
Great thread,
Any Ideas??
Gavin
Try swapping the transmit and receive wires they might be backwards.
Nz08R6 is offline
post #29 of 40 (permalink) Old 05-29-2018, 01:23 AM
R6 Track Bike
So I swapped the Tx & Rx but no change, Blk is deffinantly to Gnd...
Still annoying me!!!
1berts is offline
post #30 of 40 (permalink) Old 06-02-2018, 02:33 PM Thread Starter
Nz08R6's Avatar
Bike: 2008 R6
Garage
Have you got the come port set up correctly? As in correct buad rate etc
Nz08R6 is offline
R6 R1 YEC Cable Interface ECU BIERAAP Bike Parts For Sale 4 11-10-2014 03:12 PM
FS:YEC ECU Kit DATA Interface Cable $299 EABikes Bike Parts For Sale 0 01-08-2014 05:33 PM
Flash-Tune FTdataLink ECU Interface cable R6 '08 Team Bastardo Racing Bikes + Parts + Gear Wanted 0 11-18-2013 01:25 AM
YEC cable interface cable and misc. stuff MX558 Bike Parts For Sale 4 05-25-2013 04:36 AM
YEC Race ECU, Wire Harness, Cable Interface and software sonysnakeman Bike Parts For Sale 2 11-27-2008 05:24 AM
