HELP. Trying to change the ignition switch assembly on 2017 R6 - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 2 (permalink) Old 02-27-2019, 07:05 PM Thread Starter
Bike: 2010 YZF-R6
Im trying to change the whole ignition assembly cylinder out due to the old one being completed shattered due to a theft attempt.
I'm aware that you have to remove the fork strut bar, I loosen the main steering column bolt and the two allen bolts under the tabs, loosen then two side bolts that clamp each side down to the forks but I can't get the damn thing to come off for the life of me, I pry one side up and the other goes down I can't get it to evenly come off.
HxCGrind is offline
post #2 of 2 (permalink) Old 02-28-2019, 03:05 PM
Bike: 2015 R1
Garage
Re: HELP. Trying to change the ignition switch assembly on 2017 R6
it should just slide off by hand. are the wires to the switch holding it?
yamahacrazy is offline
2011 R6 - Wont start ignition issue....? Bradoshi Garage / Mechanical Help 2 11-26-2018 06:37 PM
R6 2017 speedo meter US can fit UK? Rewki333 Garage / Mechanical Help 0 09-05-2018 04:47 PM
R6 ignition wire for alarm install??? mytrickR6 How To's... 7 06-28-2004 02:30 PM
How do I remove my ignition (main switch) from my r6? krycek113 How To's... 5 06-11-2004 11:28 PM
2003 R6 wiring diagram and how to remove ignition switch gp125_racer General Discussions 2 05-21-2004 01:32 PM
