Steering Bearing/Race removal - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 6 (permalink) Old 04-27-2019, 02:04 PM Thread Starter
2009 R6 Track
Hey all,
I got stuck with trying to remove the lower race in my 2009 R6. The only punch I have worked for the top race, but the bottom one’ a bitch. It seems more recessed than the top race. I tried a flat head but it can’t catch the lip, any tips?
09 R6 Track
02 SV650 Track
gixxerjoe is offline
post #2 of 6 (permalink) Old 04-27-2019, 02:11 PM
Why yes I don't!!!!!!!!!!
TurboBlew's Avatar
Bike: 2007 In Heaven
Re: Steering Bearing/Race removal
usually the bushing is the troublesome part to remove from the lower triple. Are they damaged? Why are you replacing them??
TurboBlew is offline
post #3 of 6 (permalink) Old 04-28-2019, 04:00 AM Thread Starter
2009 R6 Track
i get a clicking during tech at the track and the tech guy suggested your bearings could be loose. I tried tightening to no avail. I figure since the bearings haven’t been changed in 10yrs, i might as well. I dont think anything is damaged from the looks of it.
I think the angle of the steering head to get to the lower is different? I tried using a 12" flat head, and a 5/16 punch, can't catch the edge, barely, maybe too thick?
I just bought an 8" flathead screwdriver, gonna see if that works.
Any suggestions?
09 R6 Track
02 SV650 Track
post #4 of 6 (permalink) Old 04-28-2019, 04:07 AM Thread Starter
2009 R6 Track
...some pics
ID:	361056   Click image for larger version
09 R6 Track
02 SV650 Track
post #5 of 6 (permalink) Old 04-28-2019, 04:14 AM
TurboBlew's Avatar
stick with the stock ball bearing setup... just lube and retighten.
post #6 of 6 (permalink) Old 04-28-2019, 05:58 AM Thread Starter
2009 R6 Track
yeah, but manual suggests races and bearings replace as a set.
Hence, stuck with the bottom race.
Update: Ahh, just needed a non tapered punch/rod - did the trick
09 R6 Track
02 SV650 Track
Steering damper fitment for 2005 R6 chipmunk Suspension settings 5 03-27-2019 06:44 PM
Ohlins Steering Damper on a 2018 R6? Cameron Ribeiro Garage / Mechanical Help 2 08-29-2018 09:19 AM
Steering Damper? Diew Suspension settings 58 10-29-2004 01:04 PM
Matris Steering Dampner rhangel Appearance and Exterior Mods 2 04-06-2004 03:20 PM
Questions on checking steering head dudeguy How To's... 2 03-28-2004 06:10 AM
