cleaned coils, change air filter,oil filter/oil now bike wont start please help! - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 7 (permalink) Old 05-30-2019, 07:22 PM Thread Starter
i changed my air filter from the stock one that looks like a sponge i took my air box apart in the process, if you have one i guess youve seen it it was terrible it looked like it had never been cleanee. i was very hapoy i felt like my money was well spent on this air filter considering i picked up this bike used. i had intended to replace the spark plugs did my research found out which plugs to get, buy i had no clue thete was a certain type of socket arm youd need to reach the plugs. so i just clean the coiks instead. the coils were a bitch to get out but they had ended up comeing out i cleaned them wiped them off with a damp rag never did i wet them or anything more. thwn i did my oil filter replaced the garbage original one with a k&n filter same as the air filter. i watched what i did took my time putting ut back and it still was giving me oroblens andnnot wanting to staet now or sounding weak while attempting to start. please help i was only trying to do
Jessie Velazquez is offline
post #2 of 7 (permalink) Old 05-31-2019, 01:29 PM
coachroy's Avatar
Bike: 2014 Yamaha R6
Garage
Re: cleaned coils, change air filter,oil filter/oil now bike wont start please help!
I would make sure your coils are fully seated back in place and you didn't crack or bend any of your fuel lines that run under the tank
coachroy is offline
post #3 of 7 (permalink) Old 05-31-2019, 02:46 PM
Year?
Crank but no start? No crank? Any codes? Does it at least try to start?
Most common thing, is to forget to plug the fuel tank wire harnesses back up.
The coil on plugs generally don't require cleaning. Was there oil in the spark plug well?
Avoid over-oiling the K&N replacement. If the oil gets on the electronically controlled throttle plates, it can cause them to stick.
Intuit is offline
post #4 of 7 (permalink) Old 05-31-2019, 04:34 PM
Bike: 2015 R1
Garage
K&N oil filters are garbage. if they don't rupture on you the oring will fail.
google it.
yamahacrazy is offline
post #5 of 7 (permalink) Old 05-31-2019, 07:33 PM
Agreed - watched my pit partner loose a track day because the K&N blew out first session!
Brett Stares is offline
post #6 of 7 (permalink) Old 06-01-2019, 04:11 AM
So you suggest getting a stock paper filter?
EthanALD is offline
post #7 of 7 (permalink) Old 06-01-2019, 05:26 AM
Bike: 2015 R1
Garage
the air filters are top notch. they actually flow better than BMC. but their new chinese manufacture of the oil filters for motorcycle has done them in. they even had to start recalling them due to failures. many racing orgs flat out banned aftermarket oil filters because of K&N failures.
if you really want one with the nut on the end look up Hiflo Filtro filters. the RC line is racing filters that have the nut. speculation is these guys were actually producing the original K&N filters until K&N went a cheaper route. and it's costing them business lol
