1st gear top speed in R6 and R1? - Page 3 - Yamaha R6 Forum: YZF-R6 Forums
post #21 of 35 (permalink) Old 05-03-2009, 01:14 PM
Bike: 2007 R6 Red
Re: 1st gear top speed in R6 and R1?
Before the 11,000km oil change, my brand new 2007 R6 had a first gear top speed of 125km/h, before the engine start to kick back.
On my 11,000km oil change, I decided to have my sparks plugs replaced as well. The merchand told me I wouldn't see any difference. I've still decided to have my sparks plugs changed.
After this 11,000km oil and sparks plugs change, my 2007 R6 has a 1st gear top speed of 131km/h, before the engine start to kick back (ie: reach the RPM limiter).
I don't know what happened there, that day, but the top speed definitively changed. I also noticed a quite noticiable higher engine compression that day. I tried to get an explanation, a few days later, on that matter. The mecanic wasn't able to explained this.
I moslty ride on the first and second gears, because I love soooo much raving and having this bike screems like hell :-)
dzork is offline
post #22 of 35 (permalink) Old 05-03-2009, 03:26 PM
CaliManDan35's Avatar
Bike: 2007 Yamaha R6
Well my '09 R6 is completely stock, except for appearance mods and I actually did some 1st gear pulls today because I'm trying to get off to a quicker start from a dead stop.
I never took my bike all the way to the revv limiter (what rpms does the limiter bounce off at? And is it safe to do that?)
I think I took my bike to right around 16,000rpms and my speedo was indicating 71mph. Some of you are saying you've gotten anywhere from 77-82mph. Hmm, I wonder if that's because you guys have performance mods or maybe you have taken it higher than I did?
Also...since our speedos are off...what 10% or so? That means the actual speed for the end of 1st gear on an '09 is about 64-65mph?
2007 Yamaha R6 - Integrated Taillights, Fender Eliminator, Carbon Fiber Tank Pad, Tinted Windscreen, Frame Sliders
CaliManDan35 is offline
post #23 of 35 (permalink) Old 05-03-2009, 03:53 PM
Bike: 2007 R6 Red
Good luck if you want fast drag start. This bike isn't the best at this, as it only get its power around 10,000 RPM.
About riding at high rev... I do it all the time. The RPM limiter bump at 16,500. No worries, this RMP limiter is there to protect your engine.
Some guys, out there, think by riding smootly their bike, they are doing them a favour. That is totally wrong. The torque zone is where your engine is the most confortable. What is amazing with this bike, is that its torque curve is almost linear on all the RPM range. Its torque peak is at 12,500 and its HP peak at 14,500 RMP.
I have a 12 km ride to go to work. It's mostly highway. I get on the highway on the first gear around one hundred something kilometers Then I shift on the second gear, when my engine start to kick back. I do it almost every morning.
So, again, if it would be harmfull, it would be a long time this 2007 R6 engine would have been dead. If your engine break in is done, then go for it. This bike only ask for it.
BTW, my 2007 R6 don't have any mods. Everything is stock on it.
dzork is offline
post #24 of 35 (permalink) Old 03-24-2010, 06:15 PM
You could sit on rev limiter for 20mins and do nothing to the bike. They are built and designed for every bit of razzing and abuse that you can throw it!
greenerbbb is offline
post #25 of 35 (permalink) Old 03-24-2010, 06:31 PM
My R6 eats you.
Dieselboy's Avatar
Bike: 2010 Yamaha M1
Images: 1
NESBA A | CCS #686
///If you ride like lightning, you’re gonna crash like thunder.
Dieselboy is offline
post #26 of 35 (permalink) Old 03-24-2010, 06:33 PM
R6 Pilot
Talus's Avatar
Bike: 2008 Yamaha R6S
Holy thread revival batman!
2008 Yamaha R6S
Mods: * Sportech Chrome Windscreen * Chrome Reservoir covers * MotoGP Reservoir Sock * Color Matched top triple tree w/custom decal * Tank Pad * Hard Rock Motorsports HR1 Riot Exhaust * Custom LED integrated turn signals * TAG metals fender eliminator kit w/custom lighting * Clegg's Innovations Angel Eyes * Joe Florida LED underglow kit * Euro turn signal mod * Hotbodies Flush Mount Turn Singals * Black rear shock spring * Pazzo Racing Levers * Carbon Fiber Ram Air Covers * Driven D3 Gel Grips * BMC Street Air Filter *
"There are only two kinds of people that understand Marines: Marines, and those who have met them in battle. Everyone else has a second-hand opinion."
Talus is offline
post #27 of 35 (permalink) Old 03-24-2010, 07:35 PM
Broken Give-A-**** Meter
TheDurtyDurden's Avatar
Bike: 2007 Yamaha R6S
from what i can tell there's a lot of dumbass things said in the oldass thread
2007 R6S, NEW Bridgestone BT-016 (120/70 front)
Yoshi slip-on (now chopped!!!), smoked LED integrated tail light, custom front LED blinkers, painted windscreen, lots of little touches, and lots more to come!
TheDurtyDurden is offline
post #28 of 35 (permalink) Old 06-20-2011, 11:15 PM
2007 r1 tops out at 113 in first on mine with stock gear ratio. Doesn't power wheelie without a lot of body english, until you hit at least 55 mph.
rastaR1 is offline
post #29 of 35 (permalink) Old 08-07-2017, 02:30 AM
I hit 131kph on my 06.
Aswin Mp is offline
post #30 of 35 (permalink) Old 02-27-2018, 08:15 PM
Too bad those bikes go that fast in 1st, all the noobs ride around in 1st enough as it is haha
jonathancalkins is offline
SOLUTION: Transmission 2nd Gear Slip motofabio Garage / Mechanical Help 47 06-16-2018 12:11 PM
i'm impotent =( deltaonex General Discussions 43 01-06-2012 09:23 AM
Acumen Digital Gear Indicator DG8 stoneloco808 Product Reviews 5 07-16-2011 02:02 AM
SOLUTION: Transmission 2nd Gear Slip motofabio General Discussions 12 11-14-2005 05:08 PM
Shifting into 1st Gear while cruising with clutch? Cheng General Discussions 6 04-03-2004 05:24 PM
