help computer died - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 15 (permalink) Old 03-27-2009, 10:58 AM Thread Starter
help computer died
when i turn it on i get no log on screen just blue and a message fatal eror wen computer was shut of its a dell e 510 i think not sure im at work
cLeeR257 is offline
post #2 of 15 (permalink) Old 03-28-2009, 11:42 AM
Lifetime Premium
Bike: 2007 Charcoal R6
Re: help computer died
Turn on the computer and start pressing F12 as soon as you see the dell logo. It will take you to a boot menu. Choose diagnostics and let it run. If the PC passes all diagnostics then the issue is most likely software related.
Turn on the computer and start pressing F8 as soon as you see the dell logo. This time you should get a windows boot menu. Select safe mode and press enter. If it boots into safe mode you can try a windows restore. Sometimes that will fix issues. If that doesn't work you can try some more advanced repair options while in safe mode, but I won't go into that now.
Before you try this last step I suggest you backup all of your data. If you screw this up it will erase everything from your hard drive. If done properly all of your programs and data will remain intact.
If you can't get into safe mode either, you can try a windows repair. Put in your XP disk and turn on the PC press F12 to get the boot menu and select the CD drive. make sure to press a key when it says press any key to continue. Wait for the cd to boot. Press Enter to install XP. Press F8 to agree. It will now search for currently installed versions of windows. Press R to initiate a windows repair and wait for it to finish. No matter what do not stop the repair while it is running. That can make you much worse off.
Hope this helps,
Matt
buddahson is offline
post #3 of 15 (permalink) Old 03-30-2011, 12:52 AM
josepontejos's Avatar
maybe there's a problem with the parts of your cpu, maybe it could the video card, memory card.
josepontejos is offline
post #4 of 15 (permalink) Old 03-30-2011, 01:35 AM
liking anchovies
TMNT's Avatar
Bike: 2005 ZX6R
What these guys said...
You can also try re-seating the ram (memory), and try each stick individually as one may have went to heaven.
TMNT is offline
post #5 of 15 (permalink) Old 05-05-2011, 03:41 AM
Johnathan9's Avatar
Most common problem..
You need to format your computer using boot-able CD.This will definitely work.Good luck.
Johnathan9 is offline
post #6 of 15 (permalink) Old 05-05-2011, 03:55 AM
carbon, carbon, carbon!!
07 r6's Avatar
Bike: huffy
get a new one
07 r6 is offline
post #7 of 15 (permalink) Old 05-23-2011, 12:42 PM
R6 Hill Country Eater
air226rider's Avatar
Bike: 2011 R6
Dump it, unless you have stuff you need on it. FYI its called the 'Blue Screen of Death".
Good luck bro, oh and get a mac and that shit wont happen.
2011 R6 SE (Black/Red Skulls)
Appearance: Pazzo Levers, CRG Bar-end Mirrors, Zero Gravity Double Bubble Dark Smoke, Woodcraft Cut Frame Sliders, Driven Grips, Black/Red Yamaha Res Covers, Competition Werkes Fender Eliminator, Proton Flushies
Performance: MJS Headers, Akrapovic Full Carbon Slipon, Bazzaz ZFI/AFM, Graves Block Offs, BMC Race Filter, EXUP Servo Eliminator,
air226rider is offline
post #8 of 15 (permalink) Old 05-27-2011, 07:53 PM
Technology Ninja
Shinjo's Avatar
Bike: '05 R6
Send a message via AIM to Shinjo
And this is called the "Spinning beach ball of death" which is what macs get
~Shinjo
Shinjo is offline
post #9 of 15 (permalink) Old 05-27-2011, 09:25 PM
Now you see me...
icepic's Avatar
Bike: 2007 R6 candy red
Send a message via Skype™ to icepic
step 1. press F8 while BIO screen is loading.
step 2. select last known good configuration.
this should do it, if not repeat step 1 then
step 2 select safe mode
step 3 use restore mode (if you need instructions, google or ask me)
I do this for a living i'll get you fixed up.
REFLASHED YEC ECU
ZEITRONIX DATA LOGGER W/TWEEKER
SPEEDO DRD
DRIVEN 15T (-1) 525 FRONT SPROCKET
GYTR AIR FILTER
SMOG BLOCK OFFS
GP STYLE REVERSE SHIFTING
T-TUNER MID PIPE (WELDED)
STOCK HEADERS & SLIP ON W/ EXUP CUT OUT
ACCUMEN GEAR INDICATOR
GORILLA ALARM
90 DEGREE ANGLED RED ALUMINUM VALVE STEMS
TRACTION PADS
LP CARBON FIBER FRAME SLIDERS
icepic is offline
post #10 of 15 (permalink) Old 05-27-2011, 11:39 PM
I can ban you
Mario J's Avatar
Bike: 2013 GRB STi
Images: 3
Nice thread revivals
I <3
Mario J is offline
Thoughts during sex... annguyen1981 Off Topic Talk 117 11-21-2009 04:55 PM
REAL ANTIVIRUS, need HELP from computer gods NoHoR6 The Computer Guru Section 8 01-21-2009 10:45 PM
need help! computer problem CatalystXXL18 Off Topic Talk 4 06-10-2008 06:34 PM
Computer takes forever to bootup! sparta531 The Computer Guru Section 17 05-17-2008 03:39 AM
Help Me...Computer Problem...Please PolishPete Off Topic Talk 12 12-21-2005 04:25 PM
