Flash Drive - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 11 (permalink) Old 10-04-2009, 05:26 PM Thread Starter
Flash Drive
I have a flash drive with my friends bike pics on it. It use to work fine but now everytime I put into the usb slot there use to be a window asking me how I want to open it and view the pics. Now when I go into "My Computer" and click on the drive it prompts a screen telling me I need to format it. My question is, does anyone know how to get the pics of the flash drive without having to format it so I dont loose the pics?
Israeli_R6 is offline
post #2 of 11 (permalink) Old 10-04-2009, 05:39 PM
Lifetime Premium
maxdamage2122's Avatar
Bike: 05 R6
Re: Flash Drive
your chances of recovering the pics are slim to none. the filesystem is mostly likely corrupt. how do you remove the flash drive? do you just pull it out or do you actually unmount the drive before pulling it out?
maxdamage2122 is offline
post #3 of 11 (permalink) Old 10-04-2009, 05:49 PM
08 Yamaha R6
longbrake_00's Avatar
Bike: 08 Yamaha R6
Re: Flash Drive
Drive sounds screwed.. There are some apps out there that will try to recover files as long as it can see the drive, but the good ones aren't free.
Mods:
Full Leo Exhaust, PC III, Graves Smog Block Offs, GYT-R High Flow Filter, Barnett Race Clutch, Vortex Sprocket Conversion, DID Racing Chain, GPR Steering Damper, Smoked Galfer Brake Lines, Samco Coolant Hoses, Carrozzeria Rims, Pazzo Levers, Moto-R Engine Covers, Acumen Gear Indicator, Bohemian Racing Rear Set, Speedo Healer, Graves Frame Sliders, Moto-R Spools, Knight Rider/Solid Third Eye, Gorilla 7017 Alarm, Graves Bar Ends, CRG Hindsight LS Barend Mirror, Spider Grips, Pro Bolts Fairing Bolt Kit, Lightech Engine Bolt Kit, Solo Cowl, GYT-R Black Axle Adjusters, Hotbodies Flush Mounts, Graves ExUP Removal, Puig DB Screen, Cox's Radiator Cover, Fender Eliminator, CA Tail Light, Lawstcaws Frame Plugs, Passenger Peg Covers, Stomp Grip Pads, Black Kickstand, Harris Gold Gas Cap, Carbon Tank Pad, Lightech Gold Oil Cap, Light N'Boltz, Puig Toe Guard, Race Rotors, Lamin-X Headlight Covers, Traxxion Tank Sliders, R&G Exhaust Slider, Rizoma Front and Rear Axle Sliders, PlanetSuperBikes Number Plates, Vortex Mirror Block Offs
longbrake_00 is offline
post #4 of 11 (permalink) Old 10-04-2009, 06:56 PM
Lifetime Premium
Bike: 2007 Charcoal R6
Re: Flash Drive
Look for a photo recovery tool for a camera memory card. There are some good ones out there and they are cheap or free. The full on file recovery programs tend to be more expensive. Try ZAR:
. I found a good review here:
buddahson is offline
post #5 of 11 (permalink) Old 10-06-2009, 04:12 PM Thread Starter
Re: Flash Drive
I usually just close the folder then pull the drive out....
post #6 of 11 (permalink) Old 10-08-2009, 06:50 AM
Parts Pimp
ChiefSmokeDawg's Avatar
Bike: 2002 R6, 2008 R6
Re: Flash Drive
goto the my computer on your machine whent he drive is inserted, and right click on the drive and select properties. Goto the tools tab, and select error checking. when the dialog box comes up and asks you to automatically fix errors, check that box, and also check the other box to scan for and attempt recovery of bad sectors and click ok.
This will run a checkdisk on your thumb drive and attempt to recover the lost files and bad sectors. A lot of times, if you just boot your computer up with the drive in, the checkdisk command will run automatically.
ChiefSmokeDawg is offline
post #7 of 11 (permalink) Old 10-08-2009, 07:21 AM
Bike: 07 carcoal R6
Re: Flash Drive
right click on my computer
choose "manage"
goto disk management
and see if it will let you assign a drive letter without formatting..
it may or may not work
Squidding one tentacle at a time…
07 R6
ToXIc is offline
post #8 of 11 (permalink) Old 10-08-2009, 11:43 AM
vroom
yotaismygame's Avatar
Bike: 00 R6:03 zx6r
Re: Flash Drive
Yea you have to remove it first before pulling it out. right click on the icon in the right corner and click remove.
slow ride take it easy "thats my motto"
yotaismygame is offline
post #9 of 11 (permalink) Old 12-27-2010, 01:57 PM
Re: Flash Drive
You lost the only copy of important files, and must be retrieved. Digital photo recovery hard drives, memory cards, digital cameras and other players is one of the most common data recovery. digital storage media is very fragile compared to photographic prints, and digital camera users often make a single copy of your precious photos before deleting the original. This results in tragedy when the copy unreadable.
gasshat is offline
post #10 of 11 (permalink) Old 12-27-2010, 02:24 PM
AFM #327
Doc-Ram's Avatar
Bike: 16 R3, 17R6
Re: Flash Drive
a$$hat spammer!!!
AFM #327
2019 Sponsors:
Doc-Ram is offline
WD Elements External Hard Drive Deleted all my Data!!! mystiqueskillz Off Topic Talk 8 08-09-2009 04:04 PM
DVD/CD Drive rmerchant3 The Computer Guru Section 7 03-03-2009 11:38 AM
Ducati USB Flash Drive FordForever Off Topic Talk 12 11-09-2008 11:32 AM
Help flash relay clb2man General Discussions 5 09-26-2008 02:17 PM
Did learning to ride affect the way you drive your cage? Mojo jojo General Discussions 8 03-05-2007 07:34 AM
