Steering Dampers - Page 3 - Yamaha R6 Forum: YZF-R6 Forums
 2Likes
post #21 of 44 (permalink) Old 11-16-2018, 05:44 PM
Tigertim20's Avatar
Re: Steering Dampers
Originally Posted by TurboBlew View Post
Sounds to me like you dont know what a damper actually is... a shock absorber. Stroke length aint got shit to do with anything.
Maybe you haven't mounted many dampers to different bikes?
the stroke length absolutely matters if youre silly enough to try and mount it in the wrong spot. the length of the stroke need to accommodate the rotation of the forks / bars, as well as the distance between the mounting points whether that be on the bars / forks, side fo the frame etc
A damper mounted across the tank, requires a relatively short damper, and wont have adequate stroke to be mounted in a side mount.
See attached photos - photo 1 would not work in the location in photo 2 as it would be too short, and if you DID get it mounted, it would stop the bars from turning properly in one or both directions.
Hence the universal damper, as I mentioned, is designed to accommodate mounting in a variety of locations.
That wouldnt matter for a rotary damper of course, but OP specifically asked about linear Ohlins dampers
Name:	top mount.jpg
ID:	358842   Click image for larger version
Name:	side mount.JPG
Tigertim20 is offline
post #22 of 44 (permalink) Old 11-16-2018, 10:47 PM
Even RC motorcycles have dampers. I got it before I rode a motorcycle. If I didn't have that I might have crashed already. Learned a lot of what not to do such as hold the power all the way on a power wheelie. Once it goes over the crash is catastrophic.
AntDX316 is offline
post #23 of 44 (permalink) Old 11-16-2018, 10:51 PM
AntDX316 is offline
post #24 of 44 (permalink) Old 11-17-2018, 07:11 AM
tubular radical bodacious
tecknojoe's Avatar
Bike: '14 R6
Images: 2
let me ask you this... do you currently own any of the following:
-airbag suit
-back/chest protector
-reputable model glove
-Daytona Security Evo boots or similar
yes
'14 R6 race
tecknojoe is offline
post #25 of 44 (permalink) Old 11-17-2018, 07:12 AM
Why yes I don't!!!!!!!!!!
TurboBlew's Avatar
Bike: 2007 In Heaven
Ok that didnt take long for you to indict yourself...lol.
All due respect here your reasoning is flawed.
Also its very evident you have not ridden anything insanely fast or capable of pulling the front wheel off the ground over 100mph.
Id wager you ride around with "duck" feet and favor the center of your seat.
What kind of R6 do you ride that makes any appreciable power??
TurboBlew is offline
post #26 of 44 (permalink) Old 11-17-2018, 07:21 AM
TurboBlew's Avatar
Originally Posted by tecknojoe View Post
yes
1 or all on the list?
post #27 of 44 (permalink) Old 11-17-2018, 07:26 AM
With all due respect, your accusations are offensive. Saying my RC nitro bike understanding makes me look bad and invalidates my high-performance riding skill accomplishments is offensive. I feel as though people like you don't deserve to know certain things even if it ultimately results in them making it into Hell. The only way is if I can pool everything I do into one sequential understanding pattern to cycle would it only be understood. But the amount of work to do that would be so Professional money should be made. Trying to sell ideas and correct theories that are real. Trying to save people from Hell and making $0 with still the high-chance of not being believed. To actually set transfer the reputation and credibility each and every time in a concise and clear manner that someone calls me out especially those who ride and don't even need advice. People read people like you and your advice and it steers them away from listening to people like me and they die or worse. Though some people do believe me but they don't show themselves or stick up for me at times.
Don't miss scale RC built correctly is the same as full-scale. Look at how the US Navy test model ships. They use small scaled ships then make the big thing. I know it seems kind of foolish to compare a smaller model to the real thing when you aren't an engineer at all but if you just try and think like an engineer you would understand they can relate in a way 1:1. I've rode an '18 S1000RR. 88mph in a 25mph during a demo lap. Prob hit 88mph before 1 block was up. If you consider an '18 S1000RR not high-performance enough.. I ride an '05 R6 with lots of mods. It power wheelies extremely hard at times in 1. Doesn't matter if I own no bike. A damper does matter.
AntDX316 is offline
post #28 of 44 (permalink) Old 11-17-2018, 08:18 AM
TurboBlew's Avatar
... To actually set transfer the reputation and credibility each and every time in a concise and clear manner that someone calls me out especially those who ride and don't even need advice. People read people like you and your advice and it steers them away from listening to people like me and they die or worse. Though some people do believe me but they don't show themselves or stick up for me at times.
you rode a S1000RR to <90mph and thats your sample size?
you built scale models of nitro bikes and thats how you determined a damper is required?
Stop being dramatic about the deaths of riders. Most of the street guys (90%) crash from lack of basic ride skill ability. Over reaction, panic braking, or poor mechanical condition... or a combination of the 3.
Yamaha has way more money and research resources than you could ever dream of...even on an RC scale. Do you think there is a reason the bikes YZFs dont come equipped with dampers from the production line? Like GSXRs and ZXs or CBRs?
My point? Dampers aint going to save shit for a casual street rider. Otherwise there would be GSXRs, ZXs, and CBRs in uncrashed condition.
I guarantee... a rider that claims they "need" a damper(outside of racing)... has not addressed the basic bike setup (spring rate, sag, properly lubed suspension pivots, etc) let alone proper tire pressure.
Straight Success likes this.
post #29 of 44 (permalink) Old 11-17-2018, 08:50 AM
Why do you have to talk shit about RC scale? Why don't you question why you are upset? Perhaps you are being "used" so people could ride with vulnerabilities that open themselves up to crashing and being on the ground bankrupting their families etc. Every way to make us ride and come home like nothing happened is what to do. In a way I criminally speed All the time but I do it wisely.
I did 88mph in a 25mph with less than 1 block of room to work with while in parade staggered column side by side formation. Looking back I wouldn't have done it but my confidence, focus, and feel were through the roof plus it was my only time w/ the bike so I wanted to explore the power a bit. We went on the highway later. Did 123mph on the highway w/ it but it sucked because it was limited to 9k RPM due to break-in limit. Did a 6th gear pull in 40mph and it still felt slow unlike what everyone else was saying. I had enough space to pull prob 150mph if the limiter was removed lol. Not like 150mph is fast. I do it on the R6 w/ the same spacing. Prob would have hit 170mph but idk. It felt like a toy bike. Like a big power wheels toy. I thought because it was a demo but they said it's the same as the showroom floor model. My R6 feels so much better as it's raw and skinnier but obviously the braking and some of the acceleration are no where near in comparison. Close enough though acceleration wise but braking.. the '18 S1000RR was on another level, prob 3x which is why I had confidence to go fast.
AntDX316 is offline
post #30 of 44 (permalink) Old 11-17-2018, 09:18 AM
TurboBlew's Avatar
again... your greeness is apparent. Yes the S1000RR is a nice bike.
Id bet you think the ABS, traction control, and launch control are worth something in regards to safety.
Outside of traction control... the other 2 require real skill and balls. No abs pump can compare.
Anyway... my 12yr old gsxr will accelerate away from an S1000RR like its parked. Like zero to 168 mph in 1320'. Thats a hand actuated clutch and foot shifted.
Comes across the scales at 460lbs wet. Makes nearly 3x the torque of an R6 at 1/2 the rpms...lol.
FS: 06+ steering dampers smalltrack Bike Parts For Sale 7 04-19-2013 05:54 AM
this is why you use steering dampers eviljarv General Discussions 52 04-15-2009 01:20 PM
steering dampers mittens173 Appearance and Exterior Mods 5 05-06-2008 01:14 PM
Steering Dampers AutoEuphoria Suspension settings 1 04-30-2008 01:25 PM
steering dampers DreamR6 General Discussions 22 11-25-2005 04:21 PM
