08 R6 180-190 Adjustment - Page 2 - Yamaha R6 Forum: YZF-R6 Forums
post #11 of 20 (permalink) Old 02-20-2019, 02:34 PM
Why yes I don't!!!!!!!!!!
TurboBlew's Avatar
Bike: 2007 In Heaven
Re: 08 R6 180-190 Adjustment
That should get you in the ball park for baseline settings. Then adjust from there.
TurboBlew is offline
post #12 of 20 (permalink) Old 02-20-2019, 02:48 PM Thread Starter
Thanks dude. 7 March is my next outing so I will play with it then.
R6trackrider is offline
post #13 of 20 (permalink) Old 02-20-2019, 07:03 PM
Just lean harder...
Phrozen's Avatar
Bike: 07 R6s
So I took that whole suspension setup guide to heart and tried to set the sag on my bike. It didn't work out....
I now have Íhlins 30mm carts and a TTX rear shock and I'm running 42mm front & 28mm rear sag and it rides like a dream.
I just wish I had tried setting the sag of the oem stuff like I did my Íhlins... 🤷🏼*♂️
I always thought it was supposed to be the same sag front and back, I was wrong....
Phrozen is offline
post #14 of 20 (permalink) Old 02-21-2019, 09:09 PM
dont need to change anything else
SeethalerRacing is offline
post #15 of 20 (permalink) Old 03-07-2019, 09:32 PM Thread Starter
Well I adjusted the trail. I ended up with about 523mm. It was a big adjustment for me. The bike felt like it was steering like a boat for the first two sessions until I got used to it. Running 30mm F & R Rider Sag. Stock suspension. With the adjustments I needed to take out some low speed compression on the front and a click softer on the rear rebound on my home track. It is quite bumpy and tight (2.2km).
Once adjusted I felt alot more stable in the corners and had more clearance. Good feel too. First time on the 190 Dunlops and ended up running about 3 seconds a lap quicker.
I think this setup will work well on the bigger tracks like Phillip Island and Eastern Creek.
post #16 of 20 (permalink) Old 03-31-2019, 07:51 PM Thread Starter
After another day on the new fork height I feel it still understeers more than I would like. The bike is very stable, so it is just about finding that happy medium for me. I have backed off the fork height to 520mm (-3mm) for the next day to see how that goes. Preload and rebound is fine.
post #17 of 20 (permalink) Old 05-11-2019, 03:18 AM Thread Starter
So I got to test 520mm fork height at the track and it was pretty much perfect. I lost the steering like a boat feeling it had at 523mm, but kept the stability.
I'm pretty happy with the stock front fork performance generally, but no matter what I do the rear doesn't seem to work well.
post #18 of 20 (permalink) Old 05-12-2019, 06:48 AM
Just lean harder...
Phrozen's Avatar
Bike: 07 R6s
If your running 30mm front and rear, try running 20-25mm in the rear and 30mm front.
Phrozen is offline
post #19 of 20 (permalink) Old 05-12-2019, 02:01 PM Thread Starter
Yeh, I'm not real keen on that idea. The sag on the rear is about right. The compliance is not. Stiffening up the rear would make the problem worse. I haven no problem with turn in or stability now so am not chasing geometry changes, just rear compliance.
post #20 of 20 (permalink) Old 05-21-2019, 04:13 AM
WTF Over
I am hitting cota this weekend will get stock suspension adjusted by the suspension people and report back what i find, my weight 220
masterblaster is offline
2007 r6 TPS adjustment Ckenr6 Garage / Mechanical Help 2 10-20-2018 10:09 PM
2001 Yamaha R6 (Blue) // What do ya think ? rhangel New Member Section 25 07-12-2006 06:51 PM
R6 with R1 motor??? spiderbyte Garage / Mechanical Help 25 06-28-2006 10:23 AM
standard restrictions on the 03+ R6 NickRs125 Exhaust and fuel delivery 0 07-09-2004 11:49 AM
Used 1999 R6 Valve Adjustment nivas New Member Section 5 02-09-2004 05:06 PM
