Rear Wheel Alignment - Yamaha R6 Forum: YZF-R6 Forums
 1Likes
post #1 of 17 (permalink) Old 06-05-2019, 12:44 PM Thread Starter
Hey guys new to the R6 life... i noticed my chain adjusters are not symmetric(according to lines on adjusterblock)
Its off by one line... and i can kinda see a slight angle in the wheel... I'm not sure if this is normal to get the rear sprocket lined up with the front sprocket(chain looks straight maybe a slight snaking) or the previous owner(sad face i hate previous owners) only adjusted one side to make the chain tighter but not aligned
... some experience would be helpful! looking to swap out the 525 oring style chain on the bike with a 525 xring new change this weekend probably will be adjusting everything accordingly and i saw some posts regarding the alignment ill probably just measure with calipers but ugh hope the frame isnt bent
always the risk we take buying used... love the forum and the community so far R6 seems like one the best 600s that arent crazy expensive. let me know down below!!!
Jfaris1222 is offline
post #2 of 17 (permalink) Old 06-05-2019, 01:40 PM
Why yes I don't!!!!!!!!!!
TurboBlew's Avatar
Bike: 2007 In Heaven
Re: Rear Wheel Alignment
never use a "cast" part to determine alignment.
You can make an alignment tool with some steel rods.
Or you can purchase one.
basically you slide the rods through each axle (swingarm & rear) so at least 6" sticks out on all sides. Fasten together with rubber bands. Get out your tape measure... then start making adjustments on the adjusters til they are within 1/16" of an inch.
TurboBlew is offline
post #3 of 17 (permalink) Old 06-06-2019, 10:49 AM
I like the 2 string method, needs some practice to make it not tedious but it works well & all you need is 12' or so of string and a couple bricks or other suitable objects- even a couple full quart bottles of oil would work. lol, haven't needed to do the rear on my R6 yet but the alignment marks on my Bandits chain adjusters where hysterically off- not a chance of alignment if using them
gpounce is online now
post #4 of 17 (permalink) Old 06-06-2019, 11:29 AM
Flyers28's Avatar
Bike: 07 Candy Red R6
More power to you if you like that method, haha. That method drove me insane, then I was left doubting the accuracy of my work because I was never quite sure if the strings were right. Just didn't have the patience to make it work. Pulled out the tape measure and settled for the "yep good enough" method. My adjuster blocks are pretty accurate though.
I was going to make a fancy alignment tool but I get so lazy sometimes (ok probably all the time).
Flyers28 is offline
post #5 of 17 (permalink) Old 06-06-2019, 11:57 AM
Touchdown!
Straight Success's Avatar
Bike: 2012 R6
Send a message via Skype™ to Straight Success
Use a vernier caliper. That's what I do. Place one on the end of the adjusting block, and the other end on the swing arm. Perfect measurements every time.
Chillin'... while the Lord watches over me!
I love my R6, but...there's no buts...
Straight Success is offline
post #6 of 17 (permalink) Old 06-06-2019, 01:00 PM
TurboBlew's Avatar
but how do you know the swingarm is straight?? The swingarm & rear axle are holllow and parallel. Alot easier to measure
post #7 of 17 (permalink) Old 06-06-2019, 04:05 PM
Touchdown!
Bike: 2012 R6
There is a fallacy in your statement. I'll let you go back an analyze it.
...and to answer your question...
Because Yamaha has a tolerance when manufacturing. Unless the bike has been severely crashed before, it should be within spec. QC verifies this after production.
If one is unsure, he/she could also use a meter or gauge (using precision measuring tools) to check, but on a production bike that hasn't been wrecked... no need.
post #8 of 17 (permalink) Old 06-07-2019, 02:14 PM
Straight Success likes this.
R6trackrider is offline
post #9 of 17 (permalink) Old 06-07-2019, 03:02 PM
TurboBlew's Avatar
Because Yamaha has a tolerance when manufacturing. Unless the bike has been severely crashed before, it should be within spec. QC verifies this after production...
Oh really?? Please tell us about Yamahas QC program that guarantees wheel alignment will be 100% perfect from the assembly line to the end user. Would love the details on this.
Lets wager... I use my alignment tool on your never crashed bike... I guarantee your rear axle is not perfectly aligned with the swingarm axle. Does your rear wheel spin 3+ complete revolutions when on a rear stand?
post #10 of 17 (permalink) Old 06-07-2019, 06:08 PM
Touchdown!
Bike: 2012 R6
You assumed I was referring to a wheel alignment. You see! I was talking about manufactured parts. You always want to go back and forth.
Learn to listen sometimes. You may actually learn something new. Yeah, you have some experience, but there are a few things you lack. Take it from a design mechanical engineer with a serious proven track record.
...and my bike is on point as it should be (minus a new air filter that's going in next week).
