Yamaha R6 2008 - error code 20 - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 8 (permalink) Old 04-06-2011, 11:53 AM Thread Starter
Angry Yamaha R6 2008 - error code 20
Hi,
I have an R6 08 witch sometimes show error code 20.
If i drive it 5 minuttes and the turn the engine off - and the on - the error is gone ?!
In the 5 minuttes it drives like sh.t.....
Error code 20: the atmospheric pressure sensor voltage and intake air pressure sensor voltage differ greatly.
I have had it to my Yamaha dealer where they have replaced the 2 sensors and the ignition box but i still get the error.
Almost all non original equipment has been taken off: KN-filter, Power-Commander, Xenon and so on.
The only thing left is my full akrapovic system and the rizoma indicators.
Anyone with an idea what to do next ?
Best regards
René from Denmark
RA R6 is offline
post #2 of 8 (permalink) Old 04-06-2011, 11:57 AM
Spend ALL the monies!
Jiggaman13's Avatar
Bike: 07 Blu Bomba, 77 LB 80 3D
Re: Yamaha R6 2008 - error code 20
could be a number of things, from the repair manual:
1 -
• Check the couplers for any pins that may be pulled out.
• Check the locking condition of the couplers.
• If there is a malfunction, repair it and connect the coupler securely
2 -
• Repair or replace if there is an open or short circuit.
• Between intake air pressure sensor coupler and ECU coupler.
(black/blue–black/blue)
(pink/white–pink/white)
(blue–blue)
3 -
• Execute the diagnostic mode. (Code No.)
• Replace if defective. Refer to “CHECKING THE INTAKE AIR PRESSURE SENSOR” on page 8-100.
1 -
• Check the intake air pressure sensor hose condition.
• Repair or replace the sensor hose.
2 -
• Replace if defective. Refer to “CHECKING THE ATMOSPHERIC PRESSURE SENSOR” on page 8-99.
from doing some google searching, it seems that this problem has had varying fixes, some just had a pinched or worn wire
2007 R6
05 Header || Termignoni Slip On || Power Commander III || BMC Filter || Shogun Frame Sliders || CRG Roll-A-Clicks
Clear Alternatives Smoked Integrated Tail || Proton Flushmounts || Smoked Windscreen || 8000k HID || Michelin Pilot Power 2CT
Shoei X11 || A* Black Label || A* SMX 5
Jiggaman13 is offline
post #3 of 8 (permalink) Old 04-06-2011, 12:04 PM Thread Starter
both sensors has been changed and the ignigion box
My Yamaha dealer has gone through the manual
I still have warrenty on it but the dealer dont now what to do know ???!!!
only to replace the exhaust and indicators too.......
RA R6 is offline
post #4 of 8 (permalink) Old 04-06-2011, 12:18 PM
Jiggaman13's Avatar
well if its under warranty then the dealer has to prove it those parts that are causing the code. A lot of people have the full akra exhaust that doesnt cause a code 20, and your rizomas wouldnt have a thing to do with it so i would leave it on and tell the dealership to honor their warranty
2007 R6
post #5 of 8 (permalink) Old 04-06-2011, 12:27 PM Thread Starter
well they are not trying to avoid the warrenty - but it has been at the dealer all winther where they have tested it in their test machine - and it looked ok but on my second drive the error was there again.....
they just dont know what do do next....
i can leave it at the dealer in 3 mounths again?!... but i want to drive
RA R6 is offline
post #6 of 8 (permalink) Old 04-06-2011, 02:06 PM
Parts Pimp
ChiefSmokeDawg's Avatar
Bike: 2002 R6, 2008 R6
Bring it somewhere else bro.
ChiefSmokeDawg is offline
post #7 of 8 (permalink) Old 10-13-2014, 06:20 PM
blah
Stats's Avatar
Bike: 06' R6
Thread Revival! - Getting this error now what should i do??
Stats is offline
post #8 of 8 (permalink) Old 05-23-2019, 02:20 AM
Hi,
Best regards
René from Denmark
i had this issue it happened to be a leaking hose from the AIS
grante1153 is offline
Error Code 15 Matt27 General Discussions 8 08-03-2017 08:28 PM
Error code 23 R6R 2008 Manel Garage / Mechanical Help 3 03-18-2011 01:59 PM
Error code 20 on 2008 R6 Jhan R6 General Discussions 5 03-29-2009 06:48 PM
Error Code R6 2fast4ufl General Discussions 1 06-27-2008 08:36 PM
error code 46 ThorThunder General Discussions 13 03-23-2007 02:26 AM
