Valve Adjustment - Page 16 - Yamaha R6 Forum: YZF-R6 Forums
post #151 of 157 (permalink) Old 12-15-2014, 07:50 PM
( . Y . )
MorrowDeath's Avatar
Bike: OH FOUR R599
Re: Valve Adjustment
Keep up the good work. Don't drop anything in the engine and don't have a extra bolts left over.
Make sure to torque everything down in the correct sequence as well
"If you put your mind to it, you can accomplish anything"..... Marty McFly
MorrowDeath is offline
post #152 of 157 (permalink) Old 12-17-2014, 06:51 AM
pin it to win it
bryan j's Avatar
Bike: 07 r6, 06 yz250f
When you put the cam retainers on be careful, it really means 7 ft lb on those. Steel bolts and aluminum head makes it easier to strip. But it's a simple fix
Go fast parts:
, Shorai battery.
Body:
Support the forum Vendors
bryan j is offline
post #153 of 157 (permalink) Old 12-17-2014, 08:36 AM
( . Y . )
Bike: OH FOUR R599
You'll also want to sync your throttle bodies as well im sure they are out of spec
post #154 of 157 (permalink) Old 12-18-2014, 08:11 AM
2 wheels> 4 wheels
Bike: 07 R6
Thanks for the heads up on that.
Im sure I can find a DIY on that here somewhere. I will get those done also. Thanks.
07 Raven R6
05 Acura RSX Type S
AZ05DC5 is offline
post #155 of 157 (permalink) Old 12-18-2014, 10:35 AM
( . Y . )
Bike: OH FOUR R599
Here is a 4 part DIY vid you can use that helped me out when I was doing my adjustment.
post #156 of 157 (permalink) Old 12-18-2014, 03:19 PM
pin it to win it
bryan j's Avatar
Search diy throttle body sync. Luke g has a thread on how to make a tester and perform the test. It's simple.
Go fast parts:
, Shorai battery.
Body:
bryan j is offline
post #157 of 157 (permalink) Old 05-06-2019, 01:50 PM
Thank you, that worked!
Iron59 is offline
Valve adjustment mr.zeetser General Discussions 2 08-31-2011 07:56 AM
Valve Adjustment? Polishguy712 Garage / Mechanical Help 0 07-19-2011 04:28 PM
How Can You Tell If You Need Valve Shims When Doing A Valve Adjustment? blk600cc General Discussions 12 05-10-2009 10:20 PM
How Much Would A Valve Adjustment Go For? blk600cc General Discussions 12 04-07-2009 06:39 PM
yzf valve adjustment flynlow3 How To's... 1 07-31-2006 08:01 PM
