High Pressure Radiator Cap? Cooler temps? - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 18 (permalink) Old 04-17-2014, 10:34 AM Thread Starter
timbo-slice's Avatar
Bike: 07 R6
I'm thinking of changing the rad cap (stock is 1.1 bar) to an aftermarket high pressure rad cap (2.0 bar).
My goal is to try and reduce my bikes coolant temp now I know increasing the cooling system pressure will increase the boiling point of the coolant but will it actually make my bike run cooler?
Graves and CV4 are 2 reputable brands with rad caps I found.
Has anyone done this mod?
Also what is the difference in temp I can expect?
timbo-slice is offline
post #2 of 18 (permalink) Old 04-17-2014, 12:22 PM
Why yes I don't!!!!!!!!!!
TurboBlew's Avatar
Bike: 2007 In Heaven
Re: High Pressure Radiator Cap? Cooler temps?
you dont raise pressure... you dillute the glycol content. Guaranteed its too rich.
TurboBlew is offline
post #3 of 18 (permalink) Old 04-17-2014, 03:45 PM
"The Dude abides .. "
MELK-MAN's Avatar
high psi rad cap does nothing to raise boiling point.. it simply keeps the coolant from overflowing at the 1.1bar (a 1.6bar cap would keep coolant from puking out a the temp the 1.1bar cap would allow it to pass). As you know, Graves sells one. I suppose it's handy when you are on a race grid for a few extra moments waiting for the idiot that didn't write his grid position down and is mucking about getting to the right spot. Engine temps can rise pretty fast in those situations, especially if like on most race bikes, you removed the fans.
I run 1.6bar caps on my crf450r harescramble/enduro dirt bikes (stock is 1.1bar like an R6) to keep em from puking coolant in the occasional tight woods sections, or when stuck behind a slower rider. Again, it does NOTHING for reducing the operating temp. It's just better than losing a little coolant every time you stop for a moment.
I have yet to bother with anything but stock rad cap on either of my race bikes.. even here in FL.
Run Engine Ice, ensure all your radiator fins are straight, make sure your fans are operating.. that's about it.
MELK-MAN is offline
post #4 of 18 (permalink) Old 04-20-2014, 09:59 PM
#79
#79's Avatar
Bike: 03 R6, 07 R6, '10 S1000RR
do you have a cat on your bike still? they soak up a lot of heat that in turn gets soaked into the motor, that can help too.
are you running a pc3/5? perhaps your bike is running just a bit rich, depending on your altitude that can make your bike run hotter too. I know with my BMW it helped just throwing map on a stock bike, because form factory they are tuned rich, which in turn also makes the bike run hotter. for instance one person found their AFR as high as 15.5 when optimal A/F Ratio = 13.2 - 13.5 : 1 according to dynojet.
both of these things can add up to a bit of added cooling, but its only food for 20F or so in the same conditions on my BMW. I haven't had the chance to do the same sort of thing on the Yamaha, as I already have a pipe and pc3 on it.
#79 is offline
post #5 of 18 (permalink) Old 04-21-2014, 05:39 AM
TurboBlew's Avatar
FYI...15.5 is lean as hell especially under load.
post #6 of 18 (permalink) Old 04-21-2014, 07:58 AM
#79
#79's Avatar
my bad I don't know why I typed rich.
#79 is offline
post #7 of 18 (permalink) Old 04-21-2014, 03:23 PM Thread Starter
Bike: 07 R6
Yeah I am running engine ice and distilled water, and I have a bazzaz with the zafm all tuned to an afr of 13.2 for my entire fuel map. I'm gonna try a new rad cap anyways and see what difference I get with temp. I'll make sure to let everyone know what I find out
post #8 of 18 (permalink) Old 04-21-2014, 05:00 PM
Removing the thermostat, water w/ water wetter, Samco hoses, stock cap = running temp of ~148F highway cruise
Coming off the track temps would be 155-165
Nathan - #425 - 07 Yamaha R6
35 Motorsports, Vortex Racing, Pit Posse Motorsports, Spy Optics, Suomy Helmets, 614 Paintworx, Optimal Racing, GP Tech
Nationwide Children's Hospital/Ohio Motorcyclists for Children
The Retrofit Source
natedogg624 is offline
post #9 of 18 (permalink) Old 04-21-2014, 06:01 PM
MELK-MAN's Avatar
hence the reason you NEED a thermostat. The 3rd gen especially, needs to be running about 180f+-
MELK-MAN is offline
post #10 of 18 (permalink) Old 04-21-2014, 06:13 PM
TurboBlew's Avatar
I would suggest a small amount of glycol in the cooling system if you're allowed.
radiator cap leak Dakota11 Garage / Mechanical Help 10 04-29-2011 02:57 PM
jackets for high temps? loserdude861 Safety Equipment 23 02-17-2011 08:32 PM
Bike wont start in cooler temps 07r6FL General Discussions 3 11-03-2009 07:48 AM
Oil Light, Cooler Temps brogers4242 General Discussions 3 09-14-2009 07:48 PM
FS: 07 R6 Radiator with fans and coolant reservoir and radiator cap JE824016 Bike Parts For Sale 4 07-26-2009 09:15 AM
