Yet another R6 with a charging system issue - Yamaha R6 Forum: YZF-R6 Forums
 2Likes
post #1 of 17 (permalink) Old 06-26-2018, 07:45 PM Thread Starter
3ggr6's Avatar
To start off, I sold an 07 R6r and got a 2008 with 4,500 miles. This bike sat in a garage for 4 years without being turned on. Last time it was used, it ran fine, never had an issue(used to be my brother’s bike). Needed fresh fluids and a battery which I’ve done already.
Bike ran good around the neighborhood till I did a 20 minute ride on the fwy. Getting home, it turned off on me...check engine light came on along with code 46.
I’ve done ALOT of research on multiple forums/YouTube, even went to a motorcycle shop to get a second opinion. Going through all the testing of the stator and rectifier, they come back with positive tests, including the new battery, BUT the charging system still doesn’t read when doing the multimeter to battery,5k rpm test. Of course the shop said to replace the whole charging system. I call bs.
Now my question to you guys...what am I missing? All connectors look brand new with no signs of overheating wires. Am I over looking something?
Btw, I’m not a noob trying to yank your chains. I’ve been a member since 08, but had to make a new profile due to sign in problems. Thank you guys in advance!!
3ggr6 is offline
post #2 of 17 (permalink) Old 06-27-2018, 07:34 AM
Re: Yet another R6 with a charging system issue
nice job
Cenusa Aurelian is offline
post #3 of 17 (permalink) Old 06-27-2018, 11:27 AM Thread Starter
3ggr6's Avatar
Originally Posted by Cenusa Aurelian View Post
nice job
Thank you, but the job isn’t done yet. Still need to figure this electrical problem out.
3ggr6 is offline
post #4 of 17 (permalink) Old 06-27-2018, 12:13 PM
Flyers28's Avatar
Bike: 07 Candy Red R6
Haha, ignore that man. He's on his 5 post hunt to view links. Some people just have an annoying way of going about it.
But yea I am not much help either.
What was your multimeter reading of the battery with bike off, at idle and at 5k rpm? I'm sure you already followed one, but there are some pretty good flowcharts online that will pinpoint charging issue.
Check your ground is clean too.
It might help others too if you posted your diagnostic results when testing stator and rectifier.
Straight Success likes this.
Flyers28 is offline
post #5 of 17 (permalink) Old 06-27-2018, 09:56 PM
Touchdown!
Straight Success's Avatar
Bike: 2012 R6
Send a message via Skype™ to Straight Success
Are you reading anywhere near 14.2-14.4 volts when the bike is running/reved?
Chillin'... while the Lord watches over me!
I love my R6, but...there's no buts...
Straight Success is offline
post #6 of 17 (permalink) Old 06-28-2018, 07:38 AM Thread Starter
3ggr6's Avatar
When the bike is off I get from 12.1-12.3 volts. At idle and 5k rpm...it doesn’t change.
The stator’s resistance tested at .4 ohms(my multi meter’s continuity was .3, so .3-.4=.1 ohms...right where it should be)Per manual, should be at .12-.18. I also did an A/C test while the bike was running and got good voltage all across.
The rectifier checked out good too with resistance open one way and also when flipping multimeter probes, it showed even readings.
I haven’t checked any grounds other than the battery...where should I start?
It’s not. Only voltage I get is what the battery is reading. Oh, btw...I’m using a battery tender to charge the battery to be able to turn on the bike for testing.
3ggr6 is offline
post #7 of 17 (permalink) Old 06-28-2018, 09:42 AM
Flyers28's Avatar
12.1-12.3 seems kind of low for a brand new battery. But I know that is most likely a symptom of the issue and not the cause, just pointing it out.
The bikes main ground is under the tank beneath all the connectors that sit there. Just move them aside and you sill see it. I'd inspect all ground wires (specifically main ground wire to battery). A bad ground could make it very difficult for the battery to charge.
Flyers28 is offline
post #8 of 17 (permalink) Old 06-28-2018, 09:55 AM Thread Starter
3ggr6's Avatar
Thank you. Iíll give that a check.
3ggr6 is offline
post #9 of 17 (permalink) Old 06-28-2018, 01:05 PM Thread Starter
3ggr6's Avatar
Checked the ground wires, they are all really clean with no corrosion, nicely tighten.
3ggr6 is offline
post #10 of 17 (permalink) Old 06-29-2018, 02:48 PM Thread Starter
3ggr6's Avatar
So here is a new one...did a test ride after charging the battery. 3 minutes into riding, my low oil light comes on...then goes away as Iím trying to pull over. Keep riding, 10 min later, the bikes electronics go completely off, BUT the bike keeps on riding like normal!
Rode it back home like that since I couldnít get the lights and speedometer back on after a few clutch jump starts.
Thoughts?
3ggr6 is offline
R6 error 60 issue Obeynation Garage / Mechanical Help 11 07-11-2018 07:12 PM
killer deal on full system close-out for 99-02 R6 Hammy_The_Can_Man Site Sponsored Specials 7 06-23-2004 11:31 AM
anyone here race a '99-02 R6 and removed the charging system arman General Discussions 1 03-23-2004 11:03 AM
Lean vs Rich issue with a new Full Akrapovic System.... Toomuchskillz Exhaust and fuel delivery 10 12-18-2003 11:35 AM
FYI: 2002 TiForce System fits 2003 R6 R6Elmo Exhaust and fuel delivery 6 10-24-2003 02:53 PM
