2007 R6 Idling Issue - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 19 (permalink) Old 07-13-2018, 07:06 AM Thread Starter
I have a 2007 R6 that has been having an idling issue. It runs ok until it warms up but after that, it idles rough, surges when starting from an idle, and will stall when starting from a stop unless I rev it up high. I have already replaced ignition coils with aftermarket coils and replaced plugs with Iridium plugs. I'm thinking it may be the TPS sensor but I'm not sure and I would prefer to not have to take it to a mechanic. Any help would be greatly appreciated.
jdman201 is offline
post #2 of 19 (permalink) Old 07-13-2018, 07:36 AM
Flyers28's Avatar
Bike: 07 Candy Red R6
Re: 2007 R6 Idling Issue
First off, you should only use new OEM coils. And iridium plugs are a waste of money imo.
But some info is missing here, like how many miles and is the bike stock?
Air filter clean?
You can get the service manual from r6messagent (google search). In there you will find out how to use the diagnostic menu.
Flyers28 is offline
post #3 of 19 (permalink) Old 07-13-2018, 07:39 AM Thread Starter
The bike is stock besides a K&N air filter. It has 26500 miles on it.
jdman201 is offline
post #4 of 19 (permalink) Old 07-13-2018, 07:40 AM Thread Starter
Sorry forgot. It has a KN air filter and a GYTR slip on
jdman201 is offline
post #5 of 19 (permalink) Old 07-13-2018, 08:38 AM
Flyers28's Avatar
Have the valve clearances been checked? Your at that point mileage wise.
Flyers28 is offline
post #6 of 19 (permalink) Old 07-13-2018, 08:46 AM Thread Starter
I haven't had them done yet but I'm trying to rule out anything else before then. My local shop said they couldn't get around to it for at least a month.
jdman201 is offline
post #7 of 19 (permalink) Old 07-13-2018, 02:44 PM
Check d01 d13 d14 and d15 in the diag menu , compare the reading with the service manual from there you will have a idea if itís a issue with anything throttle body related .. also is it only a slip on not a full exhaust. I hope this helps
Obeynation is offline
post #8 of 19 (permalink) Old 07-13-2018, 04:11 PM
UR B-hind Da 8 Ball
8Ball's Avatar
Bike: '03 R6, XR400, 79 GS550
You said it had a slip-on, but has the under engine muffler/cat box been removed? Have the headers been gutted (honeycomb cats in the headers removed?
Those mods are known to cause bouncing idling. And they definitely make a Fuel controller or ECU flash recommended
8Ball is offline
post #9 of 19 (permalink) Old 07-13-2018, 04:43 PM Thread Starter
The previous owner installed the slip on. The cat box is still there and I doubt any other exhaust work was done. All the diag codes are coming back to spec with the manual.
jdman201 is offline
post #10 of 19 (permalink) Old 07-14-2018, 03:03 AM
MidnightRider's Avatar
I would clean your TPS, and see if that makes a difference.
The surge really sounds like TPS to me.
Question though: Have you checked your throttle mechanism to see if the cables are fine and not frayed or broken? How about the throttle pulley next to the engine where th Lee cables end. Is it stuck, frozen? I had a similar problem that turned out that the pulley attached to the engine was actually damaged by a previous owner during a crash. They told me about the idling and power problems, but didn’t tell me why. Just a thought.
You can get a set of security torx bits and some electric cleaner and clean the TPS for decently cheap. It also could just be malaigned and need to be adjusted to spec. I know you said the reading was within spec, but the cleaning is an easy thing to do and is relatively cheap.
Could also be valves though. If it’s that, there’s not much I can tell ya other than to seek professional mechanical help. ☹️
MidnightRider is offline
Yet another R6 with a charging system issue 3ggr6 Garage / Mechanical Help 16 07-12-2018 05:30 PM
R6 error 60 issue Obeynation Garage / Mechanical Help 11 07-11-2018 07:12 PM
2006 R6 idle irregular issue BlackMamba Garage / Mechanical Help 4 07-03-2018 02:27 AM
2001 Yamaha R6 (Blue) // What do ya think ? rhangel New Member Section 25 07-12-2006 06:51 PM
standard restrictions on the 03+ R6 NickRs125 Exhaust and fuel delivery 0 07-09-2004 11:49 AM
