Running on two cylinders? - Page 2 - Yamaha R6 Forum: YZF-R6 Forums
post #11 of 41 (permalink) Old 03-10-2019, 03:28 PM
Bike: 2015 R1
Garage
Re: Running on two cylinders?
they would still heat up the exhaust pipe. you're not getting fuel to those 2 cyl if you confirmed you do get spark.
yamahacrazy is offline
post #12 of 41 (permalink) Old 03-10-2019, 03:29 PM
Bike: 2015 R1
Garage
Originally Posted by NotNattyR6 View Post
Would it be possible that the hissing sound from testing the coils in diag mode could have cause the ecu to fry? I do remember a weird smell afterwards..
it should not have fried the ecu but that doesn't mean it didn't happen. or the coils went bad. if you have ever smelled electrical parts burn you wont ever forget it.
post #13 of 41 (permalink) Old 03-10-2019, 03:32 PM Thread Starter
I moved around the fuel injectors along with the coils from the running cylinder, without any luck.. Looking like a fried ecu, if the compression test passes..
NotNattyR6 is offline
post #14 of 41 (permalink) Old 03-11-2019, 04:36 PM Thread Starter
Compression test all came back 180-185 psi, on the low end but no huge variation
post #15 of 41 (permalink) Old 03-11-2019, 07:00 PM
Bright side is, better that it passes the compression test.
If the ECU truly is bad, "voltage drop test" your grounding between engine/battery/regulator/frame.
Intuit is offline
post #16 of 41 (permalink) Old 03-21-2019, 05:40 PM Thread Starter
Swapped my ecu with my friends 07 R6, same issue. Cylinder 2 still not firing
post #17 of 41 (permalink) Old 03-21-2019, 05:53 PM
Two cylinders not firing, or cylinder two not firing? Was there any change at all since the ECU swap or truly the "same issue" ?
Intuit is offline
post #18 of 41 (permalink) Old 03-21-2019, 05:58 PM Thread Starter
No change whatsoever, exactly the same issue as before the ecu swap. Gonna dive into it again tomorrow..
post #19 of 41 (permalink) Old 03-21-2019, 05:58 PM
Motosylum Racing #132
The Evil Twin's Avatar
Bike: R6, ZX6, R1200, 400 XC-W
You said you moved the injectors around, but are they actually firing? Did you check voltage at the connectors on them or pull them all out and see fuel spray out of them all? You have compression, air and fire.... The only thing left is fuel.
An easier way to see if you have fuel to all the cylinders is to lightly spray starting fluid in the intake. If those dead cylinders start producing heat then you know it is fuel. BTW, I would use a IR temp gun to check temps as that would be a better judge of an increase in temp.
2017 #1 Middleweight F40, #3 Formula 40, #5 GTU, #10 Middleweight GP
2016 Middleweight F40 Track Champion, #3 Formula 40, #3 Middleweight F40, #8 Middleweight GP
2016 Sportsmanship Award, 2015 Crash & Burn Award, 2014 Sportsmanship Award, 2013 Amateur of the Year
#132 Proudly representing DC-Moto.net,
, and
The Evil Twin is offline
post #20 of 41 (permalink) Old 03-21-2019, 06:02 PM Thread Starter
I checked the voltage on the injector connectors, it was running 12.6-12.8v and I checked the resistance of the injector 2, it was 12.5-12.6. Swapped injector 1 with 2 and nothing changed.
2009 R6 running rough/on 3 cylinders Edward011778 Garage / Mechanical Help 3 03-30-2019 07:00 AM
2016 R6 Wont Stay Running (Sometimes) septantrionalis General Discussions 5 03-19-2019 07:01 PM
euro running lights udh2oskier Appearance and Exterior Mods 20 10-02-2004 12:07 PM
Running Light / Flasher Opinions Yogi Appearance and Exterior Mods 1 08-07-2004 10:12 AM
LP Flush Mounts Installed Now I have No Running Lights R6-Rider07 Garage / Mechanical Help 4 06-12-2004 06:26 PM
