05 R6 with one glowing header - Page 2 - Yamaha R6 Forum: YZF-R6 Forums
post #11 of 16 (permalink) Old 04-01-2019, 03:17 PM
Bike: 2015 R1
Garage
Re: 05 R6 with one glowing header
it's already written to the rom chip
yamahacrazy is offline
post #12 of 16 (permalink) Old 04-06-2019, 06:34 PM Thread Starter
addicted to track
hunzimoto's Avatar
Bike: 2004 R6
Valves are in spec. Canít get the fuel rail apart cause Iím scared of stripping the Phillips head screws so I canít get the injectors out. Nozzles look clean though. Gonna put it all together and see if the throttle bodies are synced properly
Sent from my iPad using Tapatalk
"In flying I have learned that carelesness and overconfidence are usually far more dangerous than deliberately accepted risks." --Wilbur Wright
hunzimoto is offline
post #13 of 16 (permalink) Old 04-07-2019, 12:59 PM Thread Starter
addicted to track
hunzimoto's Avatar
Bike: 2004 R6
Checked throttle body synchronization. 2, 3, 4 are all right at 7 in hg +/- .2. The #1 was at 3Ē and highest I could get it to go was 4Ē with the adjustment screw all the way in. So thereís some sort of vacuum issue. Any ideas what could cause this?
post #14 of 16 (permalink) Old 04-07-2019, 07:21 PM
PrepareForTakeOff's Avatar
Garage
Im pretty sure a bad diaphragm inside the throttle body could be a cause. I know when i fabricated my own slide stops the diaphrams were very easily torn, and i ruined a couple of them because i didnt deburr my stops. Maybe someone with a little more knowledge and experience working on these bikes will chime in for you. But i would pull the throttle body off since you are already in there and do a full inspection. Use the manual if you need a parts breakdown. Also some factory parts online sites such as yamaha parts house have good parts breakdowns to look at.
Like i said maybe someone with more than a few years experience of working on these bikes would have a little more or better input.
PrepareForTakeOff is offline
post #15 of 16 (permalink) Old 04-08-2019, 05:19 AM
Flyers28's Avatar
Bike: 07 Candy Red R6
Just an FYI I am pretty sure they are actually JIS screws. I am almost positive any screw that looks like Philips is actually JIS and I can't imagine Yamaha would mix it up on certain parts. Using regular Phillips screwdriver on JIS screws will certainly strip them. Get a set of JIS screwdrivers.
Flyers28 is offline
post #16 of 16 (permalink) Old 04-11-2019, 08:08 PM Thread Starter
addicted to track
hunzimoto's Avatar
Bike: 2004 R6
This is life changing. Luckily I didnít strip any screws cause I could tell they werenít gonna budge but I had never even heard of JIS!
R6 header mod 2003 to fit an 2009 Jippi44 Garage / Mechanical Help 0 10-09-2018 10:03 PM
2001 Yamaha R6 (Blue) // What do ya think ? rhangel New Member Section 25 07-12-2006 06:51 PM
R6 with R1 motor??? spiderbyte Garage / Mechanical Help 25 06-28-2006 10:23 AM
standard restrictions on the 03+ R6 NickRs125 Exhaust and fuel delivery 0 07-09-2004 11:49 AM
R6 questions! smoke General Discussions 18 05-05-2004 04:58 PM
