08-09 Rear Wheel Spins At 8-9MPH, Even With Clutch Pulled In? - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 4 (permalink) Old 04-09-2019, 11:33 PM Thread Starter
Moto mechanic and racer.
Tom Cat's Avatar
Bike: Many
Garage
So I have two of the same gen R6 in my garage that I'm working on. One's a Orange 09, the other is a Silver 08, identical other than the color basically.
I did a chain replacement and post lowside quick inspection on the 09, afterwards ran the rear in 1st on a rear stand to check and make sure it was good. Right off the bat the wheel was spinning at 8-9mph on the speedo in first or second, even with the clutch pulled in. Thinking this might be due to clutch cable maladjustment as it usually is, I check it since that was the side that lowsided. Other than some rash marks on the cable bracket, nothing was off, tried releasing all tension, putting it full tension, no change.
Weird thing is, it doesn't die when put in gear on the ground, which normally when it's a maladjusted clutch cable this far gone (I mean normally if there's any clutch drag I can stop the wheel by hand, but in this case it's spinning at 8-9mph) kills the bike when thrown in gear.
Having two of the same bike basically at the same time, I was able to check it against a far better maintained and never downed one. Turns out, it does the exact same thing, and is in far better shape.
Is this just something this generation of R6 does? I've never had a bike in that does that. A little bit maybe from clutch stiction, but nowhere this fast. The fact that two of the same bike from two different people doing the exact same thing leads me leads me to believe this is just the design of the 08/09 R6.
Moto Mechanic from the PNW, working and racing in SoCal
Tom Cat is offline
post #2 of 4 (permalink) Old 04-10-2019, 04:00 PM
Motosylum Racing #132
The Evil Twin's Avatar
Bike: R6, ZX6, R1200, 400 XC-W
My Ninja 6 and R6 do it too. As does my KTM. Totally normal and is just clutch drag.
2017 #1 Middleweight F40, #3 Formula 40, #5 GTU, #10 Middleweight GP
2016 Middleweight F40 Track Champion, #3 Formula 40, #3 Middleweight F40, #8 Middleweight GP
2016 Sportsmanship Award, 2015 Crash & Burn Award, 2014 Sportsmanship Award, 2013 Amateur of the Year
#132 Proudly representing DC-Moto.net,
, and
The Evil Twin is offline
post #3 of 4 (permalink) Old 04-10-2019, 07:40 PM Thread Starter
Tom Cat's Avatar
Bike: Many
Garage
Re: 08-09 Rear Wheel Spins At 8-9MPH, Even With Clutch Pulled In?
Man this was a first for me, must be a 08+ bike year thing, since most of the bikes I see are before that.
Tom Cat is offline
post #4 of 4 (permalink) Old 04-11-2019, 07:04 PM
Bike: 2015 R1
Garage
it's just the oil between the clutch disks. it normally slows to a stop after it's warm.
but just for the hell of it make sure the cable is adjusted properly.
yamahacrazy is offline
How to: 06-14 R6 Slipper Clutch Modification JacoBeRacing How To's... 69 06-15-2019 12:52 PM
Rear wheel locked up after clutch install 2003 R6 Texas2Reckless Garage / Mechanical Help 1 11-26-2018 06:54 PM
i'm impotent =( deltaonex General Discussions 43 01-06-2012 09:23 AM
How to: replace your clutch dj1298 How To's... 5 11-04-2007 05:49 PM
locking up the rear wheel is it really badddddd? lvlontaroo Tire Tech Talk 4 07-31-2004 08:09 AM
