Battery drains while driving - Yamaha R6 Forum: YZF-R6 Forums
LinkBack Thread Tools
Old 04-12-2019, 07:50 AM Thread Starter
Ole-Johan Ovreaas's Avatar
I had a burnt stator so i swapped it, along with the regulator and battery. The battery was then meeting every spec, the whole 10v @ crank, 14,5v @ 5kRPM and so on. I had a mecanic confirm it charged properly.
However. I still run out!!! When i drive for a while and stop, i can barely/cant even start it again, even with a hot engine. I have installed oxford heated grips and philips ultion H4 headlights and thats it. Could it be that these addittional items drain too much too fast?
There is no parasitic drain, my indicators are non-excistant if i use them with my headlights on and the bike is from 1999.
Runs great with battery!
Ole-Johan Ovreaas is offline
Old 04-13-2019, 10:39 AM
Bike: 2015 R1
Garage
Re: Battery drains while driving
test it all while it's hot. hell install a cheap voltmeter if you have to just to keep an eye on it. you have something failing. wiring, stator, cheap battery, I doubt the headlights unless they're both on all times, and heated grips (I assume you can turn these off). are doing it.
yamahacrazy is offline
Old 04-13-2019, 10:40 AM
Bike: 2015 R1
Garage
test it all while it's hot. hell install a cheap voltmeter if you have to just to keep an eye on it. you have something failing. wiring, stator, cheap battery, I doubt the headlights unless they're both on all times, and heated grips (I assume you can turn these off). are doing it. the 99-02 had a lot of charging issues. mainly melted connectors at the regulator.
Old 04-14-2019, 01:23 PM Thread Starter
I actually found out today that the battery charges fine if i turn the headlights off, maybe a wire is exposed in the headlight circut?
Old 04-15-2019, 06:34 PM
Bike: 2015 R1
Garage
if it can't keep up with the STOCK light bulbs then the stator isn't putting out enough voltage, the regulator isnt working properly or the wiring is defective. on a 99 I would venture to guess the wiring is getting hot from resistance. I'd be inclined to rewire the charging circuit with all new 12ga wiring.
Old 04-15-2019, 06:37 PM Thread Starter
Yeah thats what i feared 😞 is it possible that i just use a ohmmeter to find a cable with high resistance? Or would you have me replace the entire wiring loop
Old 04-15-2019, 08:11 PM
Bike: 2015 R1
Garage
absolutely. fear not. the charging system is very basic. not a whole lot of wiring to it. just buy good high amp connectors and good wire. wire it up like you're hooking up the best stereo system money can buy lol
Old 04-16-2019, 12:10 AM Thread Starter
Okay thanks for the help, ill try to find bad cables, and if not ill just replace the whole loop
Shorai BMS Battery Chargers RidersDiscount Riders Discount 0 04-03-2019 10:58 AM
Need help choosing a battery for accessories r6Ben00 Garage / Mechanical Help 7 01-12-2019 09:57 AM
'17 R6 - Battery completely dead MRodrigues1991 Garage / Mechanical Help 12 12-29-2018 08:02 PM
03 Yamaha R6 battery keeps dying Buenoo9619 General Discussions 11 12-09-2018 03:09 PM
03 Yamaha R6 battery keeps dying Buenoo9619 Garage / Mechanical Help 1 09-01-2018 04:47 PM
