Headlight circuit drains battery - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 5 (permalink) Old 04-15-2019, 03:59 PM Thread Starter
Ole-Johan Ovreaas's Avatar
Okay so my 99’ yamaha R6 runs great and the battery charges fine IF the headlights are turned off. If i drive with my headlights on, the battery drains in like 30mins, any ideas?
Ole-Johan Ovreaas is offline
post #2 of 5 (permalink) Old 04-15-2019, 05:45 PM
Re: Headlight circuit drains battery
Before jumping to the most extreme conclusions...
What are you voltages reading at the various RPM ranges?
Have you had the battery tested?
Intuit is offline
post #3 of 5 (permalink) Old 04-15-2019, 05:49 PM Thread Starter
Yeah, the battery charge reads 14,5 volts @ 5k rpm, had a mechanic double check it and he said there was no problem with the charging system, havent tested the battery but its new so i suppose it should be fine, but how do i test it anyway?
Also about a year ago the stator burned so i replaced it along with a new regulator
post #4 of 5 (permalink) Old 04-15-2019, 06:19 PM
Bike: 2015 R1
Garage
so now what kind of headlights are you using?
yamahacrazy is offline
post #5 of 5 (permalink) Old 04-15-2019, 06:23 PM Thread Starter
I used to use philips x-treme ultinon led bulbs that came with a transformer for each bulb, think they were rated at 25-ish watts, i thought they were the problem so i reinstalled the old 55w halogen bulbs, but that diddent help. Also the blinkers are close to non-exsistant when headlights are on
Battery drains while driving Ole-Johan Ovreaas Garage / Mechanical Help 7 04-16-2019 12:10 AM
Shorai BMS Battery Chargers RidersDiscount Riders Discount 0 04-03-2019 10:58 AM
Need help choosing a battery for accessories r6Ben00 Garage / Mechanical Help 7 01-12-2019 09:57 AM
03 Yamaha R6 battery keeps dying Buenoo9619 General Discussions 11 12-09-2018 03:09 PM
03 Yamaha R6 battery keeps dying Buenoo9619 Garage / Mechanical Help 1 09-01-2018 04:47 PM
