Battery drain - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 3 (permalink) Old 04-20-2019, 03:57 AM Thread Starter
Ole-Johan Ovreaas's Avatar
Unhappy Battery drains, any ideas?
Okay so i've made many posts about this issue and i want to thank everyone who has helped me understand my problem.
Bike: 1999 Yamaha R6
Now, as you can guess by the title, the problem is still not fixed. Basically what is happening is that the battery drains while driving.
Here is a breakdown:
1. The stator is aftermarket but producing sufficient voltage. Swapped last summer.
2. Regulator/rectifier is OEM and also swapped last summer.
3. Battery is a 12v 7AH aftermarket, but almost new.
4. The battery only drains while driving and not from standing stationary for a while, hence i dont think there is any parasitic drain.
5. All the cable connectors are looking good, no melting or any clearly visible damage.
6. I have installed heated grips and a phone charger, heated grips draining under 4 amps, phone charger is a couple amps, but even with these + headlights turned off, i still run out.
7. I had a mechanic look at the charging system and he said it was fine (clearly not since i ran out when i got home, also i think he just simply checked voltage @ 5k RPM)
Any ideas?? I'm going to do a complete test of everything including the cables later today, but any ideas that could save me from unnecessary work is much appreciated
Dang don't electrical problems suck?
Ole-Johan Ovreaas is offline
post #2 of 3 (permalink) Old 04-21-2019, 02:17 PM
Re: Battery drain
Remove the modifications and see whether the issues persist.
You could also try removing non-critical fuses and seeing whether the issue disappears.
Intuit is offline
post #3 of 3 (permalink) Old 04-21-2019, 04:10 PM Thread Starter
It appeared that the stator broke but i had problems before this so i assumed it stilm functioned, i HOPE my mentioned issue was caused by a failing stator
Shorai BMS Battery Chargers RidersDiscount Riders Discount 0 04-03-2019 10:58 AM
'05 Could faulty tail light and turn signals drain battery? jasonisthejason Garage / Mechanical Help 6 03-20-2019 03:11 PM
Need help choosing a battery for accessories r6Ben00 Garage / Mechanical Help 7 01-12-2019 09:57 AM
03 Yamaha R6 battery keeps dying Buenoo9619 General Discussions 11 12-09-2018 03:09 PM
03 Yamaha R6 battery keeps dying Buenoo9619 Garage / Mechanical Help 1 09-01-2018 04:47 PM
