Is this stator burned? - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 9 (permalink) Old 04-20-2019, 11:36 AM Thread Starter
Ole-Johan Ovreaas's Avatar
It the stator in the picture burned or is it just discolored from oil? The resistance i measured in the connector is hovering around 1,4 omhs
Ole-Johan Ovreaas is offline
post #2 of 9 (permalink) Old 04-20-2019, 11:47 AM Thread Starter
Update:
I measured again after removing the stator and now it measured about 0,5-0,4 i dont even understand
post #3 of 9 (permalink) Old 04-20-2019, 12:02 PM Thread Starter
Another update: while testing the stator for ac volts, it put out like 1,2 volts, did not change as i increased revs
post #4 of 9 (permalink) Old 04-20-2019, 03:58 PM
Bike: 2015 R1
Garage
Re: Is this stator burned?
in my opinion that looks cooked. usually if they're black they're bad. it should produce about 70 to 100v. even though yamaha's manuals dont show what it should be this is what most other bike's stators put out unhooked from the regulators.
this is what they should look like even after years of service.
yamahacrazy is offline
post #5 of 9 (permalink) Old 04-20-2019, 04:34 PM Thread Starter
I believe it was black from the beginning, its an aftermarket one. The strange thing is it was charging fine wednesday and thursday it was not. It was replaced at the end of summer last year, and barely has any miles on it. Any idea why it broke so soon?
post #6 of 9 (permalink) Old 04-20-2019, 04:43 PM
Bike: 2015 R1
Garage
not sure. could be a breakdown of the insulation stuff they used. one way to test this thing is see if it has continuity to ground. stick your probe in one of the 3 wires (test all 3) and touch the cover with the other probe. if you get a reading then it is grounded and why it burned up.
post #7 of 9 (permalink) Old 04-21-2019, 02:12 PM
From the limited number of photos I've seen, when they do burn up, the coils are typically different colors. For them all to be the same black... it's likely just a coating.
Intuit is offline
post #8 of 9 (permalink) Old 04-21-2019, 04:12 PM Thread Starter
Yeah but it measured at slightly higher resistance than spec and it was grounded, got a reading from the plug to the bare metal on the casing. I did the test that yamahacrazy recomended. Also it only put out like 1 volt
post #9 of 9 (permalink) Old 04-21-2019, 07:53 PM
Yep. If it tests bad then it is bad; regardless of appearances.
Intuit is offline
