Ram mount - mounting points help! - Yamaha R6 Forum: YZF-R6 Forums
 8Likes
post #1 of 16 (permalink) Old 04-20-2019, 01:26 PM Thread Starter
Hey guys, picking up my new 2018 next week, had an r3 before and mounted a ram ball mount in about the same location as shown in the pic. Since I donít have the new bike yet, I can only go by the parts diagram which shows nothing there!, and the black caps Iíve seen covering these holes in person. Wondering if there are screws in these holes already, and if so, is it ok to replace with longer one to secure ram mount on top? Are these holes even threaded? Thanks!
ID:	360932   Click image for larger version
dmm252535 is offline
post #2 of 16 (permalink) Old 04-20-2019, 02:43 PM
Peanut_EOD's Avatar
Bike: 2018 YZF-R6 Blue
Re: Ram mount - mounting points help!
I have mine on the gas tank mount.
dmm252535 likes this.
Peanut_EOD is offline
post #3 of 16 (permalink) Old 04-20-2019, 02:45 PM
Peanut_EOD's Avatar
Those holes in the top triple is where the clip-ons are bolted in.
post #4 of 16 (permalink) Old 04-20-2019, 03:09 PM Thread Starter
Thanks!, I suspected this, Iím guessing some would advice not to mess with these bolts.....definitely most ideal for the parts I already have though, and placement. Donít want to buy the gas tank mount or the expanding rubber mount that many have trouble with.
post #5 of 16 (permalink) Old 04-20-2019, 03:10 PM Thread Starter
Would this not get in the way of a tuck though? Like the mount!
post #6 of 16 (permalink) Old 04-20-2019, 03:13 PM
Peanut_EOD's Avatar
I donít think it would be a big deal to use that place to mount it. If youíre using a longer bolt and torquing it correctly. Aftermarket clip-ons donít use that bolt at all.
yamahacrazy and dmm252535 like this.
post #7 of 16 (permalink) Old 04-20-2019, 03:14 PM
Peanut_EOD's Avatar
That bolt is mainly for proper bar alignment.
post #8 of 16 (permalink) Old 04-20-2019, 03:15 PM
Peanut_EOD's Avatar
It does a little, but it will come off for track days or racing.
post #9 of 16 (permalink) Old 04-20-2019, 04:51 PM
Why yes I don't!!!!!!!!!!
TurboBlew's Avatar
Bike: 2007 In Heaven
Why not? They are not a super critical bolt. You can remove and put a longer one in to accomodate your mount. Some steering dampers piggy back off those holes. You must have a <38" chest if the stock bar position works for you. I always have to clock mine out a few inches to almost straight.
TurboBlew is offline
post #10 of 16 (permalink) Old 04-20-2019, 06:31 PM Thread Starter
Thanks to you and everyone! Honestly I gave the bolt more credit because it is keeping the clip on in alignment right? Otherwise, we’re relying solely on the clamping force of the other bolt to keep the grip from pivoting under force, right?
You also make a good point about the width of them! Honestly I haven’t even ridden it yet, but when I have sat on it I did feel the grips were fairly close together, but didn’t even consider the possibility or option of rotating them to spread them apart, is this a fairly common thing to do? Obviously the angle of them will change along with widening them...
2CO upper fairing mount/ clock mount wanted rapid van cleef Bikes + Parts + Gear Wanted 0 02-06-2019 11:57 PM
Cycle mount for gopro cameras - mirror mount RC423 Bike Parts For Sale 9 08-13-2018 01:22 PM
Mid Mount Exhausts(Slip-On's) Ed Exhaust and fuel delivery 3 07-06-2004 08:41 AM
How To: Install Wolf Slip-On (Standard Mount) for 2004 R6 Ed How To's... 4 04-30-2004 10:57 AM
Easiest way to convert for hight mount zlee Appearance and Exterior Mods 8 03-11-2004 10:04 PM
