2017 R6 wont start Please Help! - Page 2 - Yamaha R6 Forum: YZF-R6 Forums
post #11 of 13 (permalink) Old 04-27-2019, 06:20 PM
Bike: 2015 R1
Garage
Re: 2017 R6 wont start Please Help!
that hose is only $99. it would be far less expensive to take it to the dealer and pay the $89 diagnostic fee. they can read the codes with the yamaha diagnostic software, run any diagnostics with the software and test the fuel pressure.
the new yamaha diagnostic system is nothing like using a run of the mill code reader. it's far more in depth.
oh and you can thank Euro emissions regulations why you don't have the built in diagnostics on your R6 not yamaha.
yamahacrazy is offline
post #12 of 13 (permalink) Old 04-30-2019, 08:38 PM Thread Starter
Update for the 2017 r6, maybe some one will chime in, otherwise this is for future owners with similar problem. As I said the bike was crashed on the left side. I bought the 4pin to odb2 connector off eBay, and pulled the codes this morning. Got a few codes back tire code and another, but notably was the p2122 and p2128 something with the accelerator timing sensor. Pulled off all the crap to get to the sensor on the throttle body, and everything checked out ok, checked all connections and nothing was loose or damaged Cleared the codes, tried to start and still no start, but no new codes were tripped. That leaves me to think the fuel pump was bad from the crash. Pulled it out and tested it with the multimeter, seemed to me that the manual didn’t give much information on the “number 3” float position, but seems the resistance is a bit high for the manual specs. Found a replacement pump
On ebay for $70, so I’ll give that a try and update after. If anyone has an idea why the bike started barley a couple times and won’t run now help would be appreciated.
Brent Mesnick is offline
post #13 of 13 (permalink) Old 05-03-2019, 07:57 PM Thread Starter
Finally it runs! It was the fuel pump. Tell tale signs was the pump leaking fuel when the hose was disconnected. Needless to say, got a used pump off eBay for $70 and installed and bam!!! Bike stated right up!
2011 r6 cold start is very hard!!! MJ69 Garage / Mechanical Help 6 10-20-2018 11:50 PM
2002 R6 no start after transmission repair BenPretty Garage / Mechanical Help 7 10-08-2018 05:54 PM
R6 2017 speedo meter US can fit UK? Rewki333 Garage / Mechanical Help 0 09-05-2018 04:47 PM
2008 R6 Won't Start R6trackrider Garage / Mechanical Help 7 08-30-2018 03:07 PM
09 r6 was lide down an wont start sik505 R6-forum.com Site Help and Suggestions 1 06-25-2018 10:57 PM
