07 R6 idle and cold start problem - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 3 (permalink) Old 04-23-2019, 10:59 PM Thread Starter
Smile 07 R6 idle and cold start problem
My 07 R6 have some problem.
1). Cold start problem: When engine is completely cold, it will start with no problem at first, but when I try to warm up the engine and just let it idle without any throttle control, it will idle and die within 30 to 60s (RPM around 1300 to 1500 then gradually decrease and you can hear the engine start to die. Especially in cold weather). Once it die, it will hard to make it start again unless turn off the key, wait for 10 to 20s, then it will start again (the temperature is still low, and I think I have wait for 10 to 20s because of the auto-choke, plz correct me if I am wrong). Once the temperature reach 130 F then the engine will restart easily.
2). Idle problem: When the engine is in working temperature, idle in stop sign or holding the clutch to the bottom in low speed, the engine tend to die easily if release the throttle suddenly. So I tend to avoid sudden release on throttle in stop sign.
3). I just change the spark plugs, all four old spark plugs seems burn fine and evenly. The bike have 40K miles, and I learn and do the regular maintenance and oil change by myself.
4.) Do I need do a valve measurement? Will it fix the problem? The menu said do valve adjustment every 26K. Do anyone have a more detail step or video how to perform a valve measurement or adjustment?
Thanks
Jonathan Zhao is offline
post #2 of 3 (permalink) Old 04-24-2019, 06:44 AM
Re: 07 R6 idle and cold start problem
I would start with checking the battery for your cold start problems, mine has similar issues when the battery is low on power. Also check clutch cable adjustment, mine would die coming to a stop, and the cable just needed a little tightening. I'm sure someone wiser than me will chime in soon.
RedlineRider is offline
post #3 of 3 (permalink) Old 04-24-2019, 12:02 PM Thread Starter
Thanks I will try that first.
2018 Cold Start / idle fix FTECU - help!! 2018HaydenR6 Garage / Mechanical Help 2 12-21-2018 09:38 AM
2003 R6 low idle after bike heats up Luke Dixon Garage / Mechanical Help 8 12-19-2018 12:00 PM
2018 Cold Start / idle fix FTECU - help!! 2018HaydenR6 Canada 0 10-29-2018 04:23 PM
2011 r6 cold start is very hard!!! MJ69 Garage / Mechanical Help 6 10-20-2018 11:50 PM
Jumpy idle / stall when cold after new throttle body Obeynation Garage / Mechanical Help 10 07-18-2018 09:25 PM
