R6 wont start cold on starter only in gear, when warm ups starts also on starter??? - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 2 (permalink) Old 04-24-2019, 08:23 AM Thread Starter
Bike: r6 5eb
Hello,
i have R6 5eb 99 ran fine from time i got it, but now wont start on starter only in gear?
When engine warm ups starts normal also on starter like nothing was problem?
Bike was few days outside sitting in rain, could be this problem? Cdi also buzzing more than usual?
P.S: Compression is good, valves are ok.
TY, ride safe
Arrr is offline
post #2 of 2 (permalink) Old 04-27-2019, 06:13 PM
Bike: 2015 R1
Garage
Re: R6 wont start cold on starter only in gear, when warm ups starts also on starter?
are you saying if you push start the bike it will start right up but not when you try to use the starter?
check all the battery and cable connections. also check the resistance in the battery cables. as they age they can corrode and the battery voltage cannot flow good enough to turn the engine.
yamahacrazy is offline
07 R6 idle and cold start problem Jonathan Zhao Garage / Mechanical Help 2 04-24-2019 12:02 PM
2011 r6 cold start is very hard!!! MJ69 Garage / Mechanical Help 6 10-20-2018 11:50 PM
R6 Dies on Cold start SketchyFilmz General Discussions 9 10-06-2018 04:21 PM
02 r6 wont start, starter relay clicking, throttle cuts out engine when jumped killian Garage / Mechanical Help 0 07-28-2018 06:29 PM
My R6 won't start. Battery, starter, or the alternater? AyUIdiot General Discussions 24 03-31-2006 10:49 AM
