2005 Gauge cluster compatibility - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 5 (permalink) Old 05-10-2019, 01:59 AM Thread Starter
Hi guys, first post here. I got a 05 r6 used and the cluster doesnt work, only the lights on the right (neutral, right indicator, brights etc) work. I had it tested and apparently its fried. I need to find a used one from a salvage yard but i want to know if i could use a newer on such a from a 2007 or so. Which ones would work?
Jacooooo is offline
post #2 of 5 (permalink) Old 05-10-2019, 05:56 AM
Flyers28's Avatar
Bike: 07 Candy Red R6
Re: 2005 Gauge cluster compatibility
No. The pin-out on the connector is different. The headlight sub harness is also different. I think you're stuck with 2003-05 clusters if you want a straight forward swap.
Flyers28 is offline
post #3 of 5 (permalink) Old 05-10-2019, 04:15 PM
Bike: 2015 R1
Garage
if it's a 2007 R6s it should work. they made the 2nd gen all the way up to 2009
yamahacrazy is offline
post #4 of 5 (permalink) Old 05-10-2019, 05:01 PM
Flyers28's Avatar
Yea
Flyers28 is offline
post #5 of 5 (permalink) Old 05-11-2019, 02:03 AM Thread Starter
Thanks guys, i had a look now and yeah the 06-09 r6s has the same looking cluster, bike even looks the same. Im in south africa and im not sure we even get the r6s though. But either way, will look for a cluster that looks the same as mine. Found out you can actually use the newer style cluster like on the 2006 and up r6, but requires changing the wires in the pins, but then for some reason the speed reading will be off by around 15% without a speedo healer or whatever its called.
Jacooooo is offline
Steering damper fitment for 2005 R6 chipmunk Suspension settings 5 03-27-2019 06:44 PM
FS: 2005 R6 Stock & Aftermarket Parts - Ohlins, Akrapovic, Brembo, Shark Skinz & More teubank49 Bike Parts For Sale 15 03-20-2019 07:07 AM
Gauge Cluster As Diagnostics microracer Garage / Mechanical Help 2 12-18-2018 09:10 PM
2005 in a 2008 rgcoasty Garage / Mechanical Help 1 09-25-2018 06:33 PM
R6 gauge cluster to look like the R1's EricR6 Appearance and Exterior Mods 3 11-21-2003 09:55 AM
