Weird noise when clutch is let out - Page 3 - Yamaha R6 Forum: YZF-R6 Forums
post #21 of 27 (permalink) Old 05-15-2019, 04:15 PM
Bike: 2015 R1
Garage
Re: Weird noise when clutch is let out
you will hear a lot of noises however most people never mention that noise. I've never heard it on my bikes or any of the one's I've worked on. I would have at least checked the oil pressure. but that's me. the cct in your R6 is not like the 2nd gen that used a spring. the 3rd gens use one that's operated with oil pressure. if the pressure is low, the CCT will not have much tension. that's why I thought it was the CCT because the 06/07 were known for low oil pressure at idle. thus the cct was "soft" until you give it throttle to apply more oil pressure as the oil pump spins faster with the RPM of the motor supplying more pressure.
yamahacrazy is offline
post #22 of 27 (permalink) Old 05-15-2019, 09:07 PM Thread Starter
Alright I'll have the oil pressure checked out when I change the chain. Thanks.
Ravager33 is offline
post #23 of 27 (permalink) Old 05-16-2019, 05:10 PM
Did you mention the miles on that thing?
Intuit is offline
post #24 of 27 (permalink) Old 05-16-2019, 05:20 PM Thread Starter
16K, and the front sprocket nut is still on there.
post #25 of 27 (permalink) Old 05-17-2019, 03:04 PM
Bike: 2015 R1
Garage
the 3rd gens didn't have issue with the sprocket nuts backing off like the 2nd gens. yamaha changed the nut design.
post #26 of 27 (permalink) Old Today, 10:13 AM
Flyers28's Avatar
Bike: 07 Candy Red R6
I can't hear the video, but the OP says the noise comes and goes with clutch pull and release. It's most likely just clutch plate rattle. The more worn the basket gets the more you will hear this as the plates get stuck in grooves that get worn into the basket. OP, ignore all the worry about a CCT issue. This noise will not be effected by clutch action and will increase with revs. It is also quite noisy. This is not your issue based on your description of the problem. Again, I can't listen to the video and unless you guys are hearing something alarming (which his mechanics couldn't), if the noise changes with clutch pull then it's just clutch rattle, nothing to really be worried about.
Flyers28 is offline
post #27 of 27 (permalink) Old Today, 02:43 PM Thread Starter
Im sorry if I didn't explain it well enough but thats not really what I mean. To put it in another way, there is a vibration through the bike that I can kinda feel all the way up to the handle bars and it only happens when I drive on really low rpm, like the lowest possible, for example when I start and the clutch is completely out, but it also happens if I drive on really low rpm in second or third gear. Basically when I make the bike really work which I know I shouldn't, but I also don't think it should make that noise.
I asked one of the mechanics if it could be the clutch and he said no because he thought the clutch felt perfectly fine, I don't think its cct either. Honestly it sounds external but I don't know, maybe just the chain out of adjustment..
How to: 06-14 R6 Slipper Clutch Modification JacoBeRacing How To's... 68 05-14-2019 01:24 PM
Rear wheel locked up after clutch install 2003 R6 Texas2Reckless Garage / Mechanical Help 1 11-26-2018 06:54 PM
How to: replace your clutch dj1298 How To's... 5 11-04-2007 05:49 PM
Weird Engine Noise minnister General Discussions 6 06-22-2004 08:46 AM
Weird sputtering/rattling noise in new 04..normal? netjack General Discussions 2 06-11-2004 07:36 PM
