2006 R6 Multiple Codes - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 4 (permalink) Old 05-19-2019, 11:37 AM Thread Starter
My 2006 was running sweet yesterday. Came out this morning, no start. At first the temp said "high", and diag_01 displayed. After that, I have the following codes:
13
15
17
21
22
23
41
59
Code 50 has come and gone.
Going through the diag menu, the tilt sensor shows 5.0 volts, and does not change. The kickstand switch is also not registering. The voltage in the menu shows 18.6 (it.s 13.0 at the battery with the trickle on it).
Anyone else have this problem before?
IssyR6 is offline
post #2 of 4 (permalink) Old 05-19-2019, 01:57 PM Thread Starter
Re: 2006 R6 Multiple Codes
Well, I'm 99.9% sure I discovered the problem. Self-induced, of course. I did the servo mod. I was not careful enough when ordering resistors, I got 4.6 ohm resistors (was supposed to be 4.6 kohm). Well, I'm sure I fried the ECU. All of the codes are off the 1 leg of the ECU. Oops.
Anyone have an extra 2006 ECU they would like to sell?
IssyR6 is offline
post #3 of 4 (permalink) Old 05-21-2019, 05:06 PM
Bike: 2015 R1
Garage
exup servo mod?
did you try removing the resistors?
yamahacrazy is offline
post #4 of 4 (permalink) Old 05-21-2019, 07:09 PM Thread Starter
Yep, servo mod. Killed the ECU. Need to be more careful next time when ordering resistors!
IssyR6 is offline
2006 R6 Oil filter type Victor Koichi Hirano General Discussions 2 09-19-2018 01:21 PM
Considering buying an inoperable 2006 R6... Kevin Gerhold Garage / Mechanical Help 0 09-07-2018 02:05 PM
2006 R6 idle irregular issue BlackMamba Garage / Mechanical Help 4 07-03-2018 02:27 AM
2003 R6 with 12 Unknown Fault codes? JAZ013 Garage / Mechanical Help 0 06-26-2018 03:20 AM
