2006 R6 stuttering under 6k RPMs - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 1 (permalink) Old 05-20-2019, 04:32 AM Thread Starter
Hello everyone .
I searched the forum , but didn't find the exact same issue . So the bike is stuttering in low RPMs - under 6k - after that it works fine . I came to notice that as the bike gets hotter (85+ degrees celsius) the stuttering becomes worse . It happened 3 weeks ago and i got the spark plugs changed - after that it worked fine for about 300 kms ..then it started happening again. The strange thing is that both times this started happening it was on a slope - going up . Can it be the spark plugs again ? After just 300kms ? Searching through other topics i saw that the most common cause for the above is bad coil, but the guy that changed the spark plugs the first time checked them and said they are in norms.
Any ideas ? Thanks !
Veselin Todorov is offline
2006 R6 Oil filter type Victor Koichi Hirano General Discussions 2 09-19-2018 01:21 PM
Considering buying an inoperable 2006 R6... Kevin Gerhold Garage / Mechanical Help 0 09-07-2018 02:05 PM
New member 2006 R6 FlipHTX1589 New Member Section 0 08-30-2018 08:58 AM
2001 R6 power comes in and out in high rpms RidinLyon Garage / Mechanical Help 1 07-28-2018 03:57 PM
2006 R6 idle irregular issue BlackMamba Garage / Mechanical Help 4 07-03-2018 02:27 AM
