Fuel indicator light - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 4 (permalink) Old 05-21-2019, 07:09 AM Thread Starter
Ole-Johan Ovreaas's Avatar
Hi. I have a 1999 yamaha R6 and the fuel light does not turn on when i get low on gas. Ran out because of it. The light bulb still works, as when i removed the tank for other maintnance, the light stayed on. Any ideas?
Ole-Johan Ovreaas is offline
post #2 of 4 (permalink) Old 05-21-2019, 05:05 PM
Bike: 2015 R1
Garage
Re: Fuel indicator light
sounds like the thermo sensor in the tank may have gone bad. they're about $55. it works by detecting the temp of the fuel.
yamahacrazy is offline
post #3 of 4 (permalink) Old 05-22-2019, 02:37 AM Thread Starter
Any way to test it?
Also is it this part you are talking about?
I could not really find any thermo sensor
Edit: here is the part number for the fuel meter sensor thingy: 1uf857521000
post #4 of 4 (permalink) Old 05-22-2019, 03:32 AM
Bike: 2015 R1
Garage
yes, that's it. if you're going to buy a used one at least buy new gaskets.
you could try to clean the ground wire on yours first.
Fuel Tank Empty Winterization / Storage Experiment Straight Success Garage / Mechanical Help 26 03-26-2019 07:10 AM
Fuel Problem DanMerlin Exhaust and fuel delivery 7 03-01-2019 05:43 AM
No power at fuel pump bmeyer15 Garage / Mechanical Help 10 08-27-2018 11:55 AM
r6 2000 no fuel from carb to engine ? moegibike Garage / Mechanical Help 0 07-18-2018 11:07 PM
