2018 r6 engine build project - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 1 (permalink) Old 05-23-2019, 09:48 PM Thread Starter
zebeckdointerfone!
Bike: 2008 r6 2016 r6 2017 r6
Hi , for the guys here that have some experience on this area...
so i am building a new engine for my bike, i would like to hear different opinions on engine set ups
i do have a complete head work ( ported , multi radius valve job....)
carrillo rods
Lightened and Balanced crankshaft
ceramic bearings
micro polished gear box plus some another parts
anti friction coatings
suter sliper clutch
dbk stator
the list keep going
so i would like to hear different combinations and results.
cams, cam timing, air filters ,velocity stacks, exhausts....
i do have several options
mwr sbk air filter
stock air filter modified
bmc air filter
graves velocity stack
ventury stacks
08 r6 velocity stacks
graves works exhaust
2018 akrapovilc full system
before i pull de engine apart here what i had running
stock engine
graves velocity stacks (taller cones on the center)
ecu remaped
on pump gas 93 was pulling 122 hp under this conditions :sea level 73 degrees air temp 43% humidity
note i do all my work except the machine shop work
thanks in advance
O lento.
Tysta is offline
2018 R6 Matte Gray - Supersport 600 Conversion rusky Bike Build Forum 8 05-21-2019 08:38 AM
R6 Engine User - Not quite a bike owner Joca Gonzaga New Member Section 2 11-20-2018 09:58 PM
Can Someone Help Me Identify These R6 Engine Parts? teubank49 Garage / Mechanical Help 3 09-01-2018 03:55 PM
03+ R6 Engine Cutting out penfold Garage / Mechanical Help 203 10-12-2017 02:46 PM
03+ R6 Engine Cutting out penfold General Discussions 1 09-20-2007 05:47 AM
