need rectifier - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 4 (permalink) Old 05-24-2019, 01:14 PM Thread Starter
need rectifier
Have an 01 r6 need to replace the rectifier, can any recommend a brand and place to purchase one, I dont trust the rectifiers on ebay for $20.
Ron2001R6 is offline
post #2 of 4 (permalink) Old 05-25-2019, 06:17 AM
Bike: 2015 R1
Garage
Re: need rectifier
ricks motorsport electrics
yamahacrazy is offline
post #3 of 4 (permalink) Old 05-25-2019, 07:20 AM Thread Starter
Re: need rectifier
yamahacrazy, thanks for the info
post #4 of 4 (permalink) Old 06-03-2019, 06:19 PM
Drop a gear and DISAPPEAR
HAndHEldJEsuS's Avatar
Bike: 99 R6
I put a ricks on mine but it was for a cbr or gsxr I can’t remember, I jus hulled the pins out of the connectors and put them in my. I had to splice the negative and positive leads cause the one I got had two wires for positive and negative but I jus spliced the two together for each lead and soldered them together with a good splice made for soldering then crimping and it works great. It dissipates heat better than the ones on our bikes!! Was gonna put a computer fan on it to but didn’t to see how it worked first and haven’t needed the fan so. Easy to do and you won’t have a problems the stock ones have. The connectors is what causes ours to fail too much resistance that and the heat issue
RESPECT the machine! If you ever hop on your bike and you are 100% comfortable, SELL IT cause you will end up hurting or killing yourself!!
HAndHEldJEsuS is offline
Rectifier blowing main fuse Jhawley6310 General Discussions 7 05-17-2019 02:52 PM
How to wire the connector of rectifier plug jasonisthejason Garage / Mechanical Help 3 05-04-2019 07:49 PM
Recommended rectifier? jasonisthejason Garage / Mechanical Help 1 04-27-2019 05:53 PM
Help bike 2005 r6 won't start after new rectifier Shane Flom General Discussions 10 11-17-2018 05:20 PM
2000 r6 stator and rectifier problem Actrex94 General Discussions 1 07-08-2018 10:16 AM
