Front sprocket lock washer direction - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 3 (permalink) Old 05-24-2019, 07:14 PM Thread Starter
I went to change my chain and sprockets, only to find that the retaining nut and lock washer were both missing from the front sprocket.
I ordered the parts, but I'm not sure which direction the washer is supposed to face. Are those flanges supposed to face inward toward the shaft, so that when the nut is tightened down on top of it they bend and apply pressure against the nut? That's what I would assume, but they seem fairly pronounced, and they're also not evenly distributed around the circumference. I wasn't sure if they would be serving a different purpose by facing outward.
halcyon is offline
post #2 of 3 (permalink) Old 05-25-2019, 06:13 AM
Bike: 2015 R1
Garage
Re: Front sprocket lock washer direction
they go out. so after you torque the nut to spec you bend it down over the nut. you will need a big set of adjustable pliers. you only need to bend one of them down to touch the nut. you want to bend it down to one of the flat areas. don't bend it around the corners.
yamahacrazy is offline
post #3 of 3 (permalink) Old 05-25-2019, 09:35 AM Thread Starter
Got it - that's very helpful. Thanks!
halcyon is offline
Definitive: Chain & Sprocket thread........ luke geis Garage / Mechanical Help 96 09-23-2019 10:22 AM
Front Sprocket Questions _Thekid90 Garage / Mechanical Help 4 04-05-2019 04:29 PM
Front sprocket fallen off [email protected] Garage / Mechanical Help 19 01-12-2019 12:28 PM
2012 R6 - Front Sprocket making clicking noise aKwanMN Garage / Mechanical Help 12 11-19-2018 06:05 PM
2018 front sprocket nut 2018HaydenR6 Garage / Mechanical Help 0 09-16-2018 05:47 PM
